Problems with pulldata
681
02-12-2019 10:34 AM
DANASCHELLI
Hello! I'm having problems with the #pulldata function, using 123 survay. It seems to me to follow all the steps of the video (enabling your csv data in your survay) but it doesn't work. Could someone tell me where I go wrong?Thank you!!!
KassandraRodriguez
You need to replace the [ ] with { }
so $[name] needs to be ${name} and $[adCal] needs to be ${adCal}
DANASCHELLI
Thank you so much . It doesn't give error anymore, but still doesn't work.  The label "manto:" appear but if I make one choice it doesn't return any value. Is still there any error?
KassandraRodriguez
I think you need to either stick with lowercase or uppercase for both. It may be case sensitive
DANASCHELLI
Thank you so much!!! It works now!!! ❤️
