survey 123 customization report template reports beta cant generate reports
I have a problem generating a report through Survey 123? I can not use any template that have, maps, images or multiple choice questions?
The error message that appears to me is as follows:
Failed to parse "${foto_enquadra}". Field "${foto_enquadra}" does not exist or cannot be found in current parsing scope.
foto_enquadra is the name of a field that store a photo.
I used survey 123 connect to publish this survey. Attached I send excell and the template in Word.
Can someone help me?
Note: The survey connect is in the latest version.
Hi. This worked for me fine. I simply published your unmodified XLSFile and Word template into a brand new survey and I was able to create a report with no problem. Attaching the final output. You may want to add qualifiers to control the size of the image. For example:
This will add a photo with a width of 300 into your document and then set the height dynamically to preserve the original ratio of the photo.
There is nothing apparently wrong with your XLSFile or Word template.
