AnsweredAssumed Answered
How can I address error 00236 - I am using the supported elevation settings, and am still getting this error, so I can't publish online and am at dead end.
Question asked by hdean@nps.gov_nps on Feb 8, 2019
Latest reply on Feb 12, 2019 by russell_roberts-esristaff
I have spent a full day messing around with this to try to create a tool for planning purposes.  I am continuing to get errors on my layers "unsupported elevation setting" even though both are set to on ground, which is supported when I looked into error 00236 fixes.
Also, it is apparently impossible to overwrite a 3D scene, so the number of times I've retyped metadata to the point where i gave up is mind numbing.
If anyone has best practices workflow on how to get 3D simple shapes into a web app, please advice.  I also tried a work around by publishing 3D from 2D as a weblayer, which didn't work.  I can't share a weblayer from pro arc scene, so I'm not really clear on whether to bother trying to utilize 3D shapefiles from arcmap pro in an online environment - or if I should be publishing 2D with Z values and then using something online to build those up into basic shapes.
Outcomes
