4.x: Communication between custom widgets
801
02-03-2019 02:51 AM
Ranga_Tolapi
Occasional Contributor III
How to make custom widgets (typescript) communicate with each other?
To elaborate, whenever a button clicked on first custom widget it should update a label in the second custom widget (and vice versa).
HTML5, CSS, JavaScript, and JavaScript FrameworksEsri Young Professionals NetworkEsri webmapEsri Technical SupportRene Rubalcava
 arcgis javascript api 4.x typescript #jsx#accessor
MattDriscoll
Hey Ranga Satish Kumar Tolapi
You could have another class that takes in these widgets and handles communication between them. There isn't a defined or suggested way to do this within the API. The custom widgets should just have events or properties that the other widget can listen to in order to update itself.
MattDriscoll
Ranga_Tolapi
Thank you Matt Driscoll
