To minimize the overhead I am asking an Oracle database table only for specific objects through the OpenTable method.
While it works with in the first attempt, all others fail. I do not know what the issue is but I am getting an ArcGIS.Core.Data.GeodatabaseQueryexception thrown when trying to open the table based on my query description.
Below is the code how I am trying to get the data. The exception thrown is pointing to "Geometry is null geometry" which is strange since I can find multiple objects that fulfil the SQL statement.
public async void SearchValidationTables()
await QueuedTask.Run(() =>
using (Database ValidationDatabase = new Database(connectionFileValidation))
// get national string prefix
string nationalStringPrefix = "";
SQLSyntax sqlSyntax = ValidationDatabase.GetSQLSyntax();
nationalStringPrefix = sqlSyntax.GetSupportedStrings(SQLStringType.NationalStringPrefix).First();
// build query here and set it into next line
string querySQL = "SELECT * FROM SCHEMA.DBTABLE WHERE FEATURETYPE = "+ nationalStringPrefix +"'waterways'";
QueryDescription queryDescription = ValidationDatabase.GetQueryDescription(querySQL, "test");
// set the column with a unique identifier
queryDescription.SetObjectIDFields("OBJECTID");
// get data as featureclass and load it as featurelayer
try
FeatureClass fcFromTable = ValidationDatabase.OpenTable(queryDescription) as FeatureClass;
LayerFactory.Instance.CreateFeatureLayer(fcFromTable, MapView.Active.Map);
catch (GeodatabaseQueryException e)
throw e;
I found a bit more information by looking at the inner exception:
Does that mean I have to adjust the QueryLayerName?
Thomas,
Could you try setting the QueryDescription shape type?
For example, add the following after line 15 above:
I hope this helps,
--Rich
