refresh token
1413
01-28-2019 09:47 PM
lirong
I used ArcGIS runtime SDK for iOS and get the access token and the refresh token. I want to know the expiration time of the refresh token. Does anyone know this?
Tags (1)
MarkDostal
You can use the AGSOAuthConfiguration refreshTokenExpirationInterval property which is defined as: "
The requested expiration interval (in minutes) for the refreshToken generated by the
 OAuth request. The max interval can be overridden by the portal administrator.
 NOTE: For a permanent refreshToken (if the portal supports it), use -1.
If that doesn't answer your question, can you provide the following information?
- ArcGIS Runtime SDK for iOS version number (100.4, 100.3, etc)
- How are you getting the refresh Token?
- What kind of authentication are you using.
Mark
lirong
Thank you Mark! You mean I can set the time in my code like below, and this means I don't need to acquire refresh token anymore?
        config.refreshTokenExpirationInterval = -1
MarkDostal
Correct.  If the refresh token is set to -1, then the SDK will handle refreshing the token so you don't have to.  ArcGIS Online and Portal version > 1.6 support this functionality.  If you're not using AGOL and have an older Portal, then the refreshTokenExpirationInterval is not supported.
Let me know if you have any more questions,
Mark
