krobine
Feature Set symbology
Discussion created by krobine on Feb 22, 2011
I've written a model that is published to ArcGIS Server. The user will place points on the map. When run in ArcMap, the point appears. However, when I publish the map and related geoprocessing service to ArcGIS Server, the point does not appear.  I set the Import schema and symbology to a Feature Class (and also tried a Feature Layer in the .mxd)  residing in the ToolData folder but the point isn't showing up.  However, the tool still runs correctly so I know its reading the point.
Ideas?
Outcomes
