Track changes in data
406
01-21-2019 11:19 AM
HaroldHerrera1
I need to track the changes in the data that have been edited in the surveys to later check them both to see what the changes were.
The workflow is as follows: a survey can be accepted or rejected by the supervisor, if it is rejected, a field is set in AGON so that it appears in the survey inbox 123, the field worker must correct it later with Surver123. However, we do not want to lose the information from the initial survey to have a record of the change and know what was done to that survey specifically
Any suggestions? James Tedrick
JamesTedrick
Esri Esteemed Contributor
Hi Harold,
One way to do this would be to enable archiving (What is archiving?—Geodatabases | ArcGIS Desktop) on a feature class in an enterprise geodatabase and then have the Survey submit to that table.  A second would be to have a script create a copy of the first that is then given the AGON keyword to be refilled.
