AnsweredAssumed Answered
Is one able to remove base map credits in Portal?
Question asked by MarkHotz on Jan 18, 2019
Latest reply on Feb 4, 2019 by tony.kewang
I understand how to remove base map credits from within ArcMap or ArcGIS Pro.  However, my problem is that it appears in Portal's print widget and I'm not quite sure if this can be removed.  Staff here will be using these images and maps in various reports and the less clutter the better.
Does anyone know if these base map credits can be removed from within Portal?  The base map is not being used when creating hosted layers from within ArcGIS Pro (or ArcMap)...I'm just using the available base map satellite image in Portal.
Outcomes
