AnsweredAssumed Answered
Losing repeat geopoints when refreshing into inbox of a survey
Question asked by dot_mmekuria on Jan 16, 2019
Latest reply on Jan 23, 2019 by JTedrick-esristaff
At present there is a way to copy the submitted data from the outbox into a new survey through the survey123 for ArcGIS app.  But would it also make sense to bring the survey with its related locations when importing existing surveys into the inbox?  I was expecting that geopoints within a repeat would be reimported ( it is blanked out) when refreshing the inbox of a survey123 for ArcGIS app.  The documentation seems to suggest that repeats will be returned after version 2.4 and one need only setup  allowUpdates=true to the bind:esri:parameters column in the survey form.  The used is survey version is 3.1.126.  Is there a way to selectively import existing data into the webapp version ?
It is efficient for us to bring back the original repeat geolocations so that date and time changes can be done quickly for using the same geographic locations.
Can we have a similar functionality in the webapp as well.
Thank you,
Outcomes
