AnsweredAssumed Answered
Enforce PK/FK relationship using Attribute Assistant
Question asked by MollyKFoley on Jan 15, 2019
I have a feature class where you draw a polygon and put in an ID. I also have a table that is related to this feature class by the ID field. How can I make it so I cannot enter a record into the table for an ID that doesn't exist? Example:
Feature class
Polygon ID 1
Polygon ID 2
Table
Record ID 5 <----- I want to make this impossible to do
Record ID 1
Record ID 1
Record ID 2
Record ID 1
I cannot enforce a domain as the IDs can be unlimited. You can't auto-populate fields or domains. I have a relationship class defined between the feature class and table but I don't think this can do what I am describing.
EDIT: So it looks like the above is not possible via normal ArcMap avenues... would this be possible using Attribute Assistant? If so, what's the rule look like? I have used a "CREATE_LINKED_RECORD" rule that should enforce a PK/FK relationship, but it doesn't seem to be doing so. This is the rule I have:
Table Name: State_MgmtTracts
Field Name: <empty>
Value Method: CREATE_LINKED_RECORD
Value Info: State_MgmtAttrb|ID_Number|ID_Number|ID_Number|ID_Number
On Create: True
On Change (Attribute): False
On Change (Geometry): False
Manual Only: False
Rule Weight: 1
Outcomes
