Data Interoperability error with IFC "Instance is not syntactically valid"
838
01-14-2019 03:15 AM
AlessandroValra
Occasional Contributor III
I was given some IFC made with "Sierrasoft Roads" software.
Everytime I try to convert them to a featureclass using Data Interoperability's Quick Import, I always hit this error:
ISO10303-21: Skipping instance #75: Instance  is not syntactically valid.
Opening the IFC in Notepad and inspecting the instance I read:
#37=IFCCONNECTEDFACESET((#49,#56,#63,#70,#77,#84,#91,#98,#105,#112,#119,#126,#133,#140,#147,#154,#161,#168,#175,#182,#189,#196,#203,#210));
So, either the instance is indeed invalid, or the Data Interoperability cannot interpret it correctly.
If this might be of interest, opening the IFC with Civil 3D I can see the model without problem.
Some specs:
  • Data Interoperability (and Pro) version is 2.2
  • IFC version is IFC2X3
The Quick Import settings: the same as explained in a 2016 Esri post (unfortunately I cannot find the link, but only the one to this picture)
quick import settings
AdrianWelsh
MVP Honored Contributor
Alessandro,
Are you getting the error in ArcGIS Pro or in the other software? I am not sure which direction to point you in but I am tagging Bruce Harold‌ as he knows a lot about Data Interoperability.
#data interoperabiltiy#data interoperability tool extension
Spatial Data Infrastructures
BruceHarold
Alessandro, if you open a support call and share your data we can take a look at the issue.
AlessandroValra
Thank you Adrian Welsh‌. I am trying this with the Quick Import from ArcGIS Pro (v.2.2.4).
Bruce Harold‌ Thanks. I will ask because unfortunately the data is not mine, but I will surely open a ticket if I am told I can share the data, and if there's no previous knowledge on this problem. Thanks.
