AnsweredAssumed Answered
ArcGIS Pro/Explorer URL to Survey123 Issue
Question asked by ryanuthoff on Jan 11, 2019
Latest reply on Jan 14, 2019 by ryanuthoff
I am having a strange issue when creating mobile map packages in ArcGIS Pro for use in the Explorer. It used to work fine, but suddenly it no longer works and I'm not sure if the issue is with ArcGIS Pro or Explorer.
In ArcGIS Pro, I have a layer with a custom pop-up with a custom URL that links to Survey123 that transfers some attribute values to it. All of a sudden this week, it no longer works.
I noticed in the custom URL in Pro, it has has three slashes after arcgis-survey123 (arcgis-survey123:///?itemID....) when according to the ESRI documentation, it should only have two. I don't remember if it originally had two or if it always had three slashes.
Regardless, it has three slashes now, but it will not let me change it to two slashes. I type in two slashes, hit apply, close out of it, re-open it, and it has three slashes again.
Even stranger, after generating the mmpk, anything before the Survey123 URL is visible, but anything including and after the Survey123 URL disappears. So if I have text after the Survey123 URL, it doesn't display.
Has anyone else experienced this? I'm not sure if this is an issue with ArcGIS Pro or Explorer.
Outcomes
