WEBGISDR - error - can't access shared location
2772
5
01-09-2019 11:54 PM
User35488
New Contributor III
Hello There,
While trying to execute webgisdr utility, we are facing below error. Kindly suggest.
I am running this utility on portal deployed server
C:\Program Files\ArcGIS\Portal\tools\webgisdr>webgisdr.bat -e -f arcgisEnterpriseBkp.properties
Starting the WebGIS DR utility.
Cannot access the location \\Network_Storage_Location.
Exiting the WebGIS DR utility.
Environment: Federated
SERVER 1:
Portal 10.6 Server
USER1 running this service
SERVER 2:
ArcGIS Server 10.6
Data Store
USER1 running these services
Network_Storage_Location : Access and Write permission to USER1 on this location
SHARED_LOCATION = \\1.2.3.4\GISStore\EnterpriseBackup\SHARED_LOCATION
BACKUP_LOCATION = \\1.2.3.4\GISStore\EnterpriseBackup\BACKUP_LOCATION
Thanking you all for kind support
-AS
User35488
New Contributor III
Resolved issue with quite simple fix.
Network Locations need to be with some extra SLASH's in properties file
SHARED_LOCATION = \\\\1.2.3.4\\GISStore\\EnterpriseBackup\\SHARED_LOCATION
BACKUP_LOCATION = \\\\1.2.3.4\\GISStore\\EnterpriseBackup\\BACKUP_LOCATION
With Regards
-AS
JonathanQuinn
Esri Notable Contributor
Does the user running the DR tool have access to the directories as well?
User35488
New Contributor III
Yes, Infact i ran the DR tool by USER1(mentioned above)
User35488
New Contributor III
With Regards
-AS
Amarz
Occasional Contributor II
UPDATE: Error was due to newly created Files not being shared to ArcGIS Server Account.
@JonathanQuinn I am running into a similar issue. Can you review?
I am attempting to back up my MAP01 portal configuration located on Drive E: (Data) to a different Drive F: (Backup)
webgisdr config:
| MAP01 = Server | Backup = Mapped Drive | tempbackups = folder | backups = folder |
SHARED_LOCATION= \\\\MAP01\\Backup\\tempbackups
BACKUP_LOCATION = \\\\MAP01\\Backup\\backups
The error I am getting is the same. 'Cannot access the location \\MAP01\Backup\backups'
I am logged into my ArcGIS Server Account which has Full Access to both my E: & F:
Thank you for your assistance.
JonathanQuinn
The DR needs to read from the SHARED_LOCATION path, while each component needs write access to the SHARED_LOCATION path. The DR tool needs to write to the BACKUP_LOCATION path. Have you verified that the account running the DR tool can read/write to \\MAP01\Backup\backups?
