Add data widget
1350
8
01-09-2019 01:16 PM
GarethYoung1
New Contributor III
Robert Scheitlin, GISP
Is there a way on the add data widget to have the within map extent toggled off when the widget loads?
Gareth
Tags (1)
RobertScheitlin__GISP
Gareth,
  In the AddData\search\BBoxOption.js file change the postCreate function:
      postCreate: function() {
        this.inherited(arguments);
        this.bboxToggle.set("checked", false);
Gareth,
GarethYoung1
New Contributor III
Robert,
How do you remove the type menu from the add data widget?
Gareth
Gareth,
Add this css rule:
.search-data-type-options {
  display: none;
I take it none of this is clicking with you... What is it you don't understand about adding css rules to hide elements?
GarethYoung1
New Contributor III
Does anyone know how to disable the details option?
I've tried options but it also removes the add option
Gareth,
.jimu-widget-add-data .search-pane .item-card .action-bar>a[data-dojo-attach-point="detailsButton"],
.jimu-widget-add-data .secondary-pane .action-bar>a[data-dojo-attach-point="detailsButton"]{
   display: none;
GarethYoung1
New Contributor III
Thanks Robert.  That has really helped my understanding as you have to add the item inside square brackets.
GarethYoung1
New Contributor III
Does anyone know how to add the item description to the card in the add data widget?
GarethYoung1
New Contributor III
Robert,
How do you remove the layers option from the footer of the add data widget?
Gareth
