Hi, in Survey 123 connect, I'd like to add spaces in a sentence. The goal is to create a multiple choice but with sentences and not only one word. Hope you get the idea and that there is a solution ! Thank you very much
589
01-09-2019 05:40 AM
FranckMalamaire
by Anonymous User
Not applicable
Hi Franck,
Spaces are not supported in the name column and should be avoided, but spaces can be used in the label column which is what will be displayed in the survey form to the end user. The value in the name column is what will be stored in the feature service. Hope this helps.
Regards,
Phil.
FranckMalamaire
Hi Philip and thank you very much !
My bad !
I thought I had to write exactly the same things in label and name column,
Thank you again for your very kind answer it helped a lot !
Have a good day !
