Web form hour and minute buttons are reversed
557
01-08-2019 09:03 PM
GuyNizry
Occasional Contributor II
In question type of date and time on the web form, the hour and minute buttons are reversed.
Instead of displaying 6:42 the form displays 42:6.
Reversed hour and minute buttons
Is there something I can do to change that?
In addition, can I force the web form to display date format as dd/mm/yyyy instead of yyyy-mm-dd?
Note: I'm using Hebrew (he) as the form default language.
BrandonArmstrong
Hi Guy,
I am not seeing the same behavior when viewing a survey created using Survey123 Connect with Hebrew as the default language.  Can you please share the XLSForm that you used to create the survey?  Also, what is the default language of the OS and browser where you are seeing this?
The behavior with the formatting of the date appears to be a bug.  I will log that on our end to be addressed as soon as possible.  In the meantime, you can add a text question and enter a calculation such as
format-date(${previous_time},'%e:%m:%Y')
This is outlined in the 'Date formatting' section of the help documentation linked below...
Formulas—Survey123 for ArcGIS | ArcGIS
Brandon
GuyNizry
Hi Brandon
Thank you for your response.
The default language of the OS and browser is English.
I can share the XLSForm, but I'm not sure how to do that.
Guy
BrandonArmstrong
hi Guy,
You should be able to select 'Use advanced editor' in the top right of the GeoNet dialogue, or you can send the XLSForm to me at barmstrong at esri.com.
Brandon
GuyNizry
Hi Brandon,
Sorry for the late response.
Attached is the XLSForm.
Guy
