I have a test MD with 6 inch, 12 inch, 1 meter, and 1.4 meter resolution imagery. It does not make the change from the 1 meter to the 6 inch or 12 inch until the scale is 1:1000. I would like it to change around 1:3000 or so. How can I do this?
Solved! Go to Solution.
Forest
I'll write a quick answer and then follow with something more verbose.
The short answer to controlling visibility of different rasters in a mosaic dataset are the MinPS and MaxPS values in the attribute table. "Calculate Item Visibility" will set the values for you, but may not do exactly what you want depending on your different resolutions. If you're comfortable with CalculateValues, you can set those values manually.
PS means PixelSize, and will usually be in units of meters (may be feet if your MD coordinate system is state plane). If you'd rather work with photo scale, you can apply an equation to convert but I'll skip that unless you need it.
Visibility of any given raster will be ON when the resolution of the current view is between the Min and Max values. (Don't get confused by LowPS and HighPS which tell you the raw pixel sizes in your rasters. If these two values are not the same value, then your raster has pyramids)
If you want to be able to zoom in beyond full resolution, make sure your highest resolution layer has a MinPS=0
You haven't noted if you're using ArcMap or ArcGIS Pro...
See my next post for more background.
Cody B
Under the properties, general tab, you can set the minimum and maximum scale for display.
In the mosaic dataset properties?
Forest, I work with stand alone rasters, and do not know the ins and outs of mosaic datasets. The scale properties for display for me are available in the table of contents, properties for each individual raster dataset. Apologies to leave you without a targeted solution on this, but I was unaware it was a raster mosaic.
Regards,
Jim
Ah, yes. Thanks for the input Jim. I should have been more explicit in my first post.
Forest
Cody B
Forest
Adding more to my response above:
I think those are the key points I wanted to offer. If I think of more, I may post further. Let us know if you have further questions
Cody
Thanks Cody! You always give great feedback. I will experiment with the order problem soon.
I am doing the work on Arc 10.6.
FYI: I think I have the seamlines sorted out - they are looking good overall. I deleted the post. I may still need some input on the color problem.
Thanks Cody and Peter for all the help on this.
Just to extend on what Cody has put.
The primary way that the display range is defined is using the MinPS and MaxPS values.
These are range of screen pixel size at which the images should be displayed.
Pixelsize is typically used it directly relates to the resolution of the imagery.
The conversion form PS (in meters) to Scale. Scale = Pixel Size * 96/0.0254 Pixel Size (in meters) = Scale * 0.0254/96
Assuming that the four datasets exactly overlap you could set the following
Datasets | From | To | |||
MinPS | MaxPS | Scale 1: | Scale 1: | ||
6" | 0 | 0.1524 | 0 | 576 | |
12" | 15.24 | 0.3068 | 576 | 1160 | |
1m | 30.68 | 1 | 1160 | 3780 | |
1.4m | 1.4 | 14 | 3780 | 52913 |
This would result in the datasets only being displayed between the defined scale ranges such that you are always seeing the best resolution for the map scale.
If you wanted 12" to be displayed till 1:3000 then you could change to
12" | 0.1524 | 0.79375 | 576 | 3000 | |
1m | 0.79375 | 1 | 3000 | 3780 | |
1.4m | 1 | 14 | 3780 | 52913 |
You could change any of the MinPS and MaxPS value so that they overlap. Eg 6" only partially covers the 12" and you might set the MinPS of the 12" to 0 so that in those areas the 12" is also considered. In these areas with both 6 and 12" the question is now which should be displayed. The system will actually try and attempt to determine the most appropriate first (ie closest to natural scale), but these values can be overwritten by the ZOrder filed or mosaic method and appropriate attribute.
Note that Calculate Cell Size Ranges attempts to determine the appropriate MinPS and MaxPS values based on the overlapping imagery and their respective pixel sizes and availability of pyramids, but sometimes it is better to define the value explicitly. The rules are very useful cases where you have datasets that should always form a background at lower priority or you want to define explicit rules.
[Note. This is an edited version. In the original version of this reply, I had put LoPS/HiPS instead of MinPS/MaxPS in some places. I also clarified that PS values in these examples are in meters)
