sql to arcgis online
691
01-08-2019 10:06 AM
JeremyMullins
We're trying to assist a client in writing a Python script that reads and writes from an AGOL feature layer to a SQL database and vice versa without having to use ArcGIS for Server.
Is this possible?
JoshuaBixby
MVP Esteemed Contributor
Syncing data between AGOL/Portal feature layers and non-Esri data format  is possible, it just takes a lot more work than if you are syncing using an Esri format.  One workflow is identified in the updating_features_in_a_feature_layer | ArcGIS for Developers
