AnsweredAssumed Answered
MapView goto not working for queryFeatures() result?
Question asked by vlantaca on Jan 4, 2019
Latest reply on Jan 5, 2019 by rscheitlin
I am trying to write code that will query from a FeatureLayer using queryFeatures() and then call MapView goTo to zoom to that result. I am verifying that the query matches the attributes of the expected attributes when I query for a single objectid, but MapView goTo doesn't work when I try to zoom to the Graphics from the query.
However, if I create my own Graphics manually, it works as expected.
I have created an example with two buttons demonstrating my issue below. One button "workingButton" correctly zooms to some manually created Graphics. The other "notWorkingButton" tries to zoom to the result of a query, but doesn't work.
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Street Sweeping Routes</title>
  <script src="https://ajax.googleapis.com/ajax/libs/jquery/3.3.1/jquery.min.js"></script>
  <link rel="stylesheet" href="https://js.arcgis.com/4.10/esri/css/main.css">
  <script src="https://js.arcgis.com/4.10/"></script>
  <style>
    html,
    body{
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 70%;
      width: 100%;
  </style>
  <script>
    var app = {};
    require([
      "esri/Map",
      "esri/views/MapView",
      "esri/layers/FeatureLayer",
      "esri/widgets/Legend",
      "esri/PopupTemplate",
      "esri/Graphic",
      "dojo/domReady!"
    ], function(
      Map, MapView, FeatureLayer, Legend, PopupTemplate, Graphic
      var fields = [
        alias: "OBJECTID",
        type: "oid"
        alias: "Street_seg",
        type: "integer"
        alias: "Route",
        type: "string"
        alias: "Miles ",
        type: "double"
        alias: "Drive_time",
        type: "double"
        alias: "Av_side",
        type: "string"
        alias: "Low_addr",
        type: "integer"
        alias: "High_addr",
        type: "integer"
        alias: "St_prefix",
        type: "string"
        alias: "St_name",
        type: "string"
        alias: "St_type",
        type: "string"
        alias: "St_suffix",
        type: "string"
        alias: "Mode",
        type: "string"
        alias: "Meander",
        type: "smallinteger"
        alias: "LoopNum",
        type: "integer"
        alias: "ServiceDay",
        alias: "ID",
        type: "double"
        alias: "Street_ID",
        type: "double"
        alias: "ServiceSeq",
        type: "integer"
        alias: "Day",
        type: "string"
        alias: "Schedule",
        type: "string"
        alias: "Shape",
        type: "geometry"
        alias: "Shape.STLength()",
        type: "double"
      pTemplate = new PopupTemplate({
        content: [{
          type: "fields",
          fieldInfos: [{
            fieldName: "OBJECTID",
            label: "OBJECTID",
            fieldName: "Street_seg",
            label: "Street_seg",
            fieldName: "Route",
            label: "Route",
            fieldName: "Miles",
            label: "Miles ",
            fieldName: "Drive_time",
            label: "Drive_time",
            fieldName: "Av_side",
            label: "Av_side",
            fieldName: "Low_addr",
            label: "Low_addr",
            fieldName: "High_addr",
            label: "High_addr",
            fieldName: "St_prefix",
            label: "St_prefix",
            fieldName: "St_name",
            label: "St_name",
            fieldName: "St_type",
            label: "St_type",
            fieldName: "St_suffix",
            label: "St_suffix",
            fieldName: "Mode",
            label: "Mode",
            fieldName: "Meander",
            label: "Meander",
            fieldName: "LoopNum",
            label: "LoopNum",
            fieldName: "ServiceDay",
            label: "ServiceDay",
            fieldName: "ID",
            label: "ID",
            fieldName: "Street_ID",
            label: "Street_ID",
            fieldName: "ServiceSeq",
            label: "ServiceSeq",
            fieldName: "Day",
            label: "Day",
            fieldName: "Schedule",
            label: "Schedule",
            fieldName: "Shape",
            label: "Shape",
            fieldName: "Shape.STLength()",
            label: "Shape.STLength()",
      var defaultSym = {
        type: "simple-line", // autocasts as new SimpleLineSymbol()
        color: "#EBEBEB",
        width: 3,
        style: "solid"
       * Set a size visual variable on the renderer. Size visual variables
       * create continuous ramps that map low data values to small icons
       * and high data values to large icons. Features
       * with data values in between the min and max data values are assigned
       * a size proportionally between the min and max sizes specified in
       * `minSize` and `maxSize` or `stops`.
      var renderer = {
        type: "unique-value",
        defaultSymbol: defaultSym,
        field: "Schedule",
        uniqueValueInfos: [
            value: "First Monday of the month",
            label: "First Monday of the month",
            symbol: {
              style: "solid",
              type: 'simple-line',
              width: 3,
              color: [252, 32, 32, 0.5] // fourth value is opacity (from 0 to 1)
            value: "Second Monday of the month",
            label: "Second Monday of the month",
            symbol: {
              style: "solid",
              width: 3,
              color: [252, 93, 35, 0.5]
            value: "First Tuesday of the month",
            label: "First Tuesday of the month",
            symbol: {
              style: "solid",
              width: 3,
              color: [255, 240, 38, 0.5]
            value: "Second Tuesday of the month",
            label: "Second Tuesday of the month",
            symbol: {
              style: "solid",
              width: 3,
              color: [113, 255, 43, 0.5]
            value: "First Wednesday of the month",
            label: "First Wednesday of the month",
            symbol: {
              style: "solid",
              width: 3,
              color: [42, 255, 156, 0.5]
            value: "Second Wednesday of the month",
            label: "Second Wednesday of the month",
            symbol: {
              style: "solid",
              width: 3,
              color: [41, 233, 255, 0.5]
            value: "First Thursday of the month",
            label: "First Thursday of the month",
            symbol: {
              style: "solid",
              width: 3,
              color: [40, 90, 255, 0.5]
            value: "Second Thursday of the month",
            label: "Second Thursday of the month",
            symbol: {
              style: "solid",
              width: 3,
              color: [118, 40, 255, 0.5]
            value: "First Friday of the month",
            label: "First Friday of the month",
            symbol: {
              style: "solid",
              width: 3,
              color: [168, 40, 255, 0.5]
            value: "Second Friday of the month",
            label: "Second Friday of the month",
            symbol: {
              style: "solid",
              width: 3,
              color: [255, 40, 233, 0.5]
      app.pLineLayer = new FeatureLayer({
        url: "https://giswebservices.ci.salinas.ca.us/arcgis/rest/services/PublishedServices/CurrentSweeperRoutes/MapServer/0",
        outFields: ["*"],
        fields: fields,
        renderer: renderer,
        popupTemplate: pTemplate,
        minScale: 0,
        maxScale: 0
      var map = new Map({
        basemap: "dark-gray",
        layers: [app.pLineLayer]
      var view = new MapView({
        container: "viewDiv",
        map: map,
        center: [-121.6555, 36.6777],
        zoom: 13
      console.log(app.pLineLayer);
      selectGraphic = null;
       * Add layers to layerInfos on the legend
      var legend = new Legend({
        view: view,
        layerInfos: [
          layer: app.pLineLayer,
          title: "Street Sweeping"
      view.ui.add(legend, "top-right");
      $('#workingButton').click(function(){
        // First create a line geometry (this is the Keystone pipeline)
        var polyline = {
          type: "polyline", // autocasts as new Polyline()
          paths: [
            [-111.30, 52.68],
            [-98, 49.5],
            [-93.94, 29.89]
        // Create a symbol for drawing the line
        var lineSymbol = {
          type: "simple-line", // autocasts as SimpleLineSymbol()
          color: [150, 150, 255],
          width: 4
        // Create an object for storing attributes related to the line
        var lineAtt = {
          Name: "Keystone Pipeline",
          Owner: "TransCanada",
          Length: "3,456 km"
        polylineGraphic = new Graphic({
          geometry: polyline,
          symbol: lineSymbol,
          attributes: lineAtt,
          popupTemplate: { // autocasts as new PopupTemplate()
            title: "{Name}",
            content: [{
              type: "fields",
              fieldInfos: [{
                fieldName: "Name"
                fieldName: "Owner"
                fieldName: "Length"
        console.log("working polyline", polyline);
        console.log("working graphic", polylineGraphic);
        view.when(function(){
          view.goTo({
            target: polylineGraphic,
            animate: true
          }).then(function(){
            view.popup.open({
              features: [polylineGraphic],
      $('#notWorkingButton').click(function(){
        queryParams = app.pLineLayer.createQuery();
        queryParams.where = "OBJECTID = 1709";
        app.pLineLayer.queryFeatures(queryParams).then(function(results){
          console.log("FeatureSet:", results);
          // go to that graphic
            view.goTo({
              target: results.features[0], // Graphic object
              zoom: 20
  </script>
</head>
<body>
  <div id="viewDiv"></div>
  <input type="submit" id="workingButton" value="working">
  <input type="submit" id="notWorkingButton" value="not working">
</body>
</html>
Outcomes
