Error: Unable to connect to ArcGIS Online
3402
12-31-2018 11:19 AM
natashamichelman
I am trying to add data from ArcGIS Online from ArcMap and keep getting an error message saying Unable to connect to ArcGIS Online. I am, however, able to sign into my account from any browser I open with no problems whatsoever. I'm not sure what is happening here. I even uninstalled Mcafee.
Tags (1)
Scott_Harris
Try opening ArcGIS Administrator > Advanced... > Manage Portal Connections... > what is listed here? Make sure it says https://www.arcgis.com
Scott_Harris
by Anonymous User
Not applicable
Hi Natasha,
In addition to Scott's suggestion, it's probably worthwhile to check the ArcGIS Online connection utility test for any helpful errors. To do so:
1. With ArcMap open, right-click the little globe icon in the system tray of your computer:
2. Select "Run Connection Test." Any failures there? Hopefully that can clarify what's causing the error.
-Lauren
natashamichelman
Hi Lauren thankyou for your response.
I did run the Connection Test and everything passed.
I restarted the computer after having uninstalling Mcafee and that seemed to do the trick here.
Perhaps it was a firewall notion.
Thankyou for your response.
~ Natasha
CamillaBañares
I'm having the same problem earlier. Thanks for this tips 😁
Very much appreciated
