This seems like a bug, but I may be missing something. Here are the steps I follow:
1. Change to a new version in my published utility network service.
2. Find I want to attempt a change that requires network topology to be disabled.
3. Execute the "Disable Network Topology" GP tool. This completes successfully.
4. Want to re-enable so I attempt to "Enable Network Topology"
5. This results in an error with the message "Operation is only supported on the DEFAULT version"
6. When I return to the DEFAULT version I see that Network Topology remains enabled, just like I left it.
So it seems its possible to *disable* network topology on a version below DEFAULT but not possible to re-enable it. If I've missed something any pointers would be much appreciated.
Thx,
Ed
Solved! Go to Solution.
It works this way to support bulk data editing workflows (e.g., when a new section of the network is brought over from a data conversion vendor).
1. Disable topology in a version
2. Perform bulk updating of data (faster without topology)
3. Reconcile and post
I hope this helps.
--Rich
I hope this helps.
--Rich
Thanks Rich!
