Transfer z values from DEM to the vertices of polygons
1713
12-19-2018 03:57 AM
KatharinaHeider
Hi there,
I have a cataster map and a DEM. Step 1 is to transfer the z values of the DEM to the vertices of the polygons in the cadaster map. The second step to calculate the standard deviation of the vertices per polygon (the z values from the DEM).
In order to achieve sep 1: I interpolated the z values with the DEM using the interpolate shape tool of the 3D Analyst. Now I can see that the z values are transfered to the vertices in ArcScene but how can I work with these values in order to calculate the standard deviation?
I hope somebody has an answer
Best,
Katharina
KatharinaHeider
Thanks for your reply, Adrian!
However, the problem was that the z-values were not in the attribute table and only visible in ArcScene.
But I figured out a work around:
1) Convert the polygon vertices to points (tool: feature vertices to points)
2) Enable 3D of new point data set using DEM (tool: interpolate shape)
3) Add z-values to attribute table of new point data set (tool: add z information)
4) Calculate standard deviation per polygon in a new table (tool: summary statistics)
5) Join table to original polygon data set
AdrianWelsh
MVP Honored Contributor
Hi Katharina,
Can you use the Spatial Statistics toolbar to calculate the standard deviation?
Statistical analysis—Help | ArcGIS for Desktop
KatharinaHeider
AdrianWelsh
Thanks for sharing that! It looks like it's all solved. Nice workaround and use of tools too!
