AnsweredAssumed Answered
Is multi-processing supported in custom ArcGis Pro scripts?
Question asked by jmanriquez on Dec 17, 2018
I am having problems running a multi-process script when executed from the ArcGIS Pro application.  The script works fine when invoked from the command line.
Here is sample code to reproduce the problem:
import arcpy
import multiprocessing
def mp_process(inputs):
    task = inputs
    # do some work
    return task
if __name__ == "__main__":
    # create pool
    pool = multiprocessing.Pool(2)
    arcpy.AddMessage(str(pool.map(mp_process, [1,2,3,4])))
This simple geo-processing script fails to execute when invoked from ArcGIS Pro.  The following exception is reported:
_pickle.PicklingError: Can't pickle <function mp_process at 0x000001C5CD672510>: attribute lookup mp_process on __main__ failed.
I can run this script from the command line with no issues, but from ArcGIS Pro it throws this exception.  Does anyone know if there is a way to implement multi-processing in ArcGIS Pro custom geoprocessing tools??
thanks
Outcomes
