Not able to run downstream trace in UN
545
12-14-2018 08:26 AM
VikramA
Hi all,
I configured the UN with all required parameters. After configuration, appended Geometric Network data to Utility Network. Appended data successfully and Enable Network Topology successfully and found no error in it. Subnetline is also created with Feeder tap as Subnetwork controller for Medium Voltage tier. In the given condition, when I am trying to execute downstream trace, trace result giving error as Subnetwork controller not found.
Please suggest.
