Exception when zooming up-down
1343
12-13-2018 01:59 AM
Jean-ChristopheBertolini
New Contributor III
ArcGIS Runtime 100.3
App WPF
Layers : shapefile + Feature Layer + OpenStreetMap
This is just for information if that can help developers:
Esri.ArcGISRuntime.ArcGISRuntimeException
  HResult=0x80131500
  Message=Internal error exception. Error creating depth stencil view!:
c:\daily_r\rtc\runtimecore\c_api\src\mapping\map_view\geo_view.cpp(203) : error : Exception caught in RT_GeoView_pulse
  Source=Esri.ArcGISRuntime
  Arborescence des appels de procédure :
   à Esri.ArcGISRuntime.ArcGISException.HandleCoreError(CoreError error, Boolean throwException)
   à RuntimeCoreNet.GeneratedWrappers.Interop.CheckError(IntPtr errorHandle, Boolean throwOnFailure, GCHandle wrapperHandle)
   à RuntimeCoreNet.GeneratedWrappers.CoreGeoView.Pulse()
   à Esri.ArcGISRuntime.UI.Controls.GeoView.Esri.ArcGISRuntime.Internal.IDxSurfaceSource.Pulse()
   à Esri.ArcGISRuntime.Internal.HostedSurfaceElement.CompositionTarget_Rendering(Object sender, EventArgs e)
   à System.Windows.WeakEventManager.ListenerList`1.DeliverEvent(Object sender, EventArgs e, Type managerType)
   à System.Windows.WeakEventManager.DeliverEvent(Object sender, EventArgs args)
   à Esri.ArcGISRuntime.Internal.RenderingWeakEventManager.OnCompositeTargetRendering(Object sender, EventArgs e)
   à System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
   à System.Windows.Media.MediaContext.AnimatedRenderMessageHandler(Object resizedCompositionTarget)
   à System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   à System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
   à System.Windows.Threading.DispatcherOperation.InvokeImpl()
   à System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
   à MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj)
   à System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   à System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   à System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   à MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
   à System.Windows.Threading.DispatcherOperation.Invoke()
   à System.Windows.Threading.Dispatcher.ProcessQueue()
   à System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   à MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   à MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   à System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
   à MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
   à MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
   à System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
   à System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
   à Esri.ArcGISRuntime.Internal.HostedSurfaceElement.SurfaceBackgroundUiWorker(Object arg)
   à System.Threading.ThreadHelper.ThreadStart_Context(Object state)
   à System.Threading.ThreadHelper.ThreadStart(Object obj)
MichaelBranscomb
Esri Frequent Contributor
This error appears to come from our DirectX11-based rendering code.
Please can you run dxdiag on the machine where you saw this error, and attach the results? (https://support.microsoft.com/en-us/help/4028644/windows-open-and-run-dxdiagexe)
It may also be worth checking for an updated graphics driver: either from the device vendor or from the graphics card vendor.
Cheers
Mike
New Contributor III
Hi Mike,
Please find here after the result.
jcb
System Information
      Time of this report: 12/13/2018, 16:39:55
             Machine name: JCBERTOLINI03
               Machine Id: {357FA637-FF2C-4E9E-BCC0-501D1194696D}
         Operating System: Windows 10 Professionnel 64-bit (10.0, Build 17134) (17134.rs4_release.180410-1804)
                 Language: French (Regional Setting: French)
      System Manufacturer: Hewlett-Packard
             System Model: HP ProDesk 490 G2 MT
                     BIOS: BIOS Date: 10/15/14 16:21:51 Ver: 04.06.05 (type: BIOS)
                Processor: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz (8 CPUs), ~3.6GHz
                   Memory: 16384MB RAM
      Available OS Memory: 16310MB RAM
                Page File: 10215MB used, 8526MB available
              Windows Dir: C:\WINDOWS
          DirectX Version: DirectX 12
      DX Setup Parameters: Not found
         User DPI Setting: 96 DPI (100 percent)
       System DPI Setting: 96 DPI (100 percent)
          DWM DPI Scaling: Disabled
                 Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
           DxDiag Version: 10.00.17134.0001 64bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
           Card name: Intel(R) HD Graphics 4600
        Manufacturer: Intel Corporation
           Chip type: Intel(R) HD Graphics Family
            DAC type: Internal
         Device Type: Full Device (POST)
          Device Key: Enum\PCI\VEN_8086&DEV_0412&SUBSYS_21F5103C&REV_06
       Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
 Device Problem Code: No Problem
 Driver Problem Code: Unknown
      Display Memory: 2160 MB
    Dedicated Memory: 112 MB
       Shared Memory: 2048 MB
        Current Mode: 1920 x 1080 (32 bit) (60Hz)
         HDR Support: Not Supported
    Display Topology: Internal
 Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
     Color Primaries: Red(0.636242,0.334484), Green(0.309094,0.623547), Blue(0.150891,0.067883), White Point(0.313977,0.329602)
   Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
        Monitor Name: Generic PnP Monitor
       Monitor Model: HP ZR2330w
          Monitor Id: HWP3069
         Native Mode: 1920 x 1080(p) (60.000Hz)
         Output Type: DVI
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
      Advanced Color: Not Supported
         Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll
 Driver File Version: 20.19.0015.4835 (English)
      Driver Version: 20.19.15.4835
         DDI Version: 12
      Feature Levels: 11_1,11_0,10_1,10_0,9_3,9_2,9_1
        Driver Model: WDDM 2.0
 Graphics Preemption: Primitive
  Compute Preemption: Thread group
            Miracast: Not Supported by WiFi driver
 Hybrid Graphics GPU: Integrated
      Power P-states: Not Supported
      Virtualization: Not Supported
          Block List: No Blocks
  Catalog Attributes: Universal:N/A Declarative:N/A
   Driver Attributes: Final Retail
    Driver Date/Size: 16/10/2017 01:00:00, 39861272 bytes
         WHQL Logo'd: Yes
     WHQL Date Stamp: Unknown
   Device Identifier: {D7B78E66-4752-11CF-6F61-FA01BAC2D935}
           Vendor ID: 0x8086
           Device ID: 0x0412
           SubSys ID: 0x21F5103C
         Revision ID: 0x0006
  Driver Strong Name: oem1.inf:5f63e534dd898f5e:iHSWD_w10:20.19.15.4835:pci\ven_8086&dev_0412&subsys_21f5103c
      Rank Of Driver: 00D10001
         Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
         DXVA2 Modes: DXVA2_ModeMPEG2_VLD  DXVA2_ModeMPEG2_IDCT  DXVA2_ModeVC1_D2010  DXVA2_ModeWMV9_IDCT  DXVA2_ModeVC1_IDCT  DXVA2_ModeH264_VLD_NoFGT  DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT  DXVA2_ModeH264_VLD_Stereo_NoFGT  DXVA2_ModeH264_VLD_Multiview_NoFGT  DXVA2_ModeHEVC_VLD_Main
   Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
        D3D9 Overlay: Supported
             DXVA-HD: Supported
        DDraw Status: Enabled
          D3D Status: Enabled
          AGP Status: Enabled
       MPO MaxPlanes: 1
            MPO Caps: Not Supported
         MPO Stretch: Not Supported
     MPO Media Hints: Not Supported
         MPO Formats: Not Supported
    PanelFitter Caps: Not Supported
 PanelFitter Stretch: Not Supported
Sound Devices
            Description: Haut-parleurs (Realtek High Definition Audio)
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0221&SUBSYS_103C21F5&REV_1000
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: RTKVHD64.sys
         Driver Version: 6.00.0001.7548 (English)
            WHQL Logo'd: Yes
          Date and Size: 30/06/2015 00:00:00, 4525800 bytes
            Other Files:
        Driver Provider: Realtek Semiconductor Corp.
         HW Accel Level: Basic
              Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Video Capture Devices
Number of Devices: 0
DirectInput Devices
      Device Name: Souris
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Clavier
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: USB Keyboard
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x0461, 0x0010
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ Hub USB racine (USB 3.0)
| Vendor/Product ID: 0x8086, 0x8CB1
| Matching Device ID: USB\ROOT_HUB30
| Service: USBHUB3
| Driver: USBHUB3.SYS, 11/9/2018 03:49:37, 565048 bytes
+-+ Périphérique USB composite
| | Matching Device ID: USB\COMPOSITE
| | Service: usbccgp
| | Driver: usbccgp.sys, 4/12/2018 00:33:52, 168864 bytes
| +-+ Périphérique d’entrée USB
| | | Matching Device ID: USB\Class_03&SubClass_01
| | | Service: HidUsb
| | | Driver: hidusb.sys, 4/12/2018 00:33:52, 42496 bytes
| | | Driver: hidclass.sys, 4/12/2018 00:33:52, 173568 bytes
| | | Driver: hidparse.sys, 6/8/2018 10:01:36, 46080 bytes
| | +-+ Périphérique clavier PIH
| | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | Service: kbdhid
| | | | Driver: kbdhid.sys, 4/12/2018 00:33:52, 40448 bytes
| | | | Driver: kbdclass.sys, 4/12/2018 00:33:52, 63904 bytes
| | Vendor/Product ID: 0x0461, 0x4D0F
| | Service: HidUsb
| +-+ Souris HID
| | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | Service: mouhid
| | | Driver: mouhid.sys, 4/12/2018 00:33:52, 33280 bytes
| | | Driver: mouclass.sys, 4/12/2018 00:33:52, 56728 bytes
Gameport Devices
PS/2 Devices
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 442.2 GB
Total Space: 939.9 GB
File System: NTFS
      Model: WDC WD10EZEX-60M2NA0
      Drive: 😧
 Free Space: 1.0 GB
Total Space: 12.8 GB
File System: NTFS
      Drive: E:
 Free Space: 0.1 GB
Total Space: 0.1 GB
File System: FAT32
      Drive: G:
      Model: hp DVDRAM GTB0N
     Driver: c:\windows\system32\drivers\cdrom.sys, 10.00.17134.0137 (French), 6/15/2018 05:36:47, 159744 bytes
System Devices
     Name: Intel(R) H97 Chipset LPC Controller - 8CC6
Device ID: PCI\VEN_8086&DEV_8CC6&SUBSYS_21F5103C&REV_00\3&11583659&0&F8
   Driver: C:\WINDOWS\system32\DRIVERS\msisadrv.sys, 10.00.17134.0001 (English), 4/12/2018 00:33:49, 18848 bytes
     Name: Contrôleur hôte PCI vers USB standard étendu
Device ID: PCI\VEN_8086&DEV_8CAD&SUBSYS_21F5103C&REV_00\3&11583659&0&D0
   Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 10.00.17134.0001 (French), 4/12/2018 00:33:52, 95648 bytes
   Driver: C:\WINDOWS\system32\drivers\usbport.sys, 10.00.17134.0001 (French), 4/12/2018 00:33:52, 412576 bytes
   Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 10.00.17134.0001 (French), 4/12/2018 00:33:52, 514464 bytes
     Name: Contrôleur AHCI SATA standard
Device ID: PCI\VEN_8086&DEV_8C82&SUBSYS_21F5103C&REV_00\3&11583659&0&FA
   Driver: C:\WINDOWS\system32\DRIVERS\storahci.sys, 10.00.17134.0001 (English), 4/12/2018 00:33:49, 156056 bytes
     Name: Intel(R) 9 Series Chipset Family PCI Express Root Port 1 - 8C90
Device ID: PCI\VEN_8086&DEV_8C90&SUBSYS_21F5103C&REV_D0\3&11583659&0&E0
   Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 10.00.17134.0441 (French), 11/9/2018 03:48:23, 375296 bytes
     Name: Intel(R) 9 Series Chipset Family SMBus Host Controller - 8CA2
Device ID: PCI\VEN_8086&DEV_8CA2&SUBSYS_21F5103C&REV_00\3&11583659&0&FB
   Driver: n/a
     Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_21F5103C&REV_0C\01000000684CE00000
   Driver: C:\WINDOWS\system32\DRIVERS\rt640x64.sys, 10.03.0723.2015 (French), 2/17/2016 16:27:02, 896768 bytes
   Driver: C:\WINDOWS\system32\RtNicProp64.dll, 1.02.0000.0006 (French), 2/17/2016 16:27:02, 91240 bytes
     Name: Pont processeur hôte standard PCI
Device ID: PCI\VEN_8086&DEV_0C00&SUBSYS_21F5103C&REV_06\3&11583659&0&00
   Driver: n/a
     Name: Intel(R) HD Graphics 4600
Device ID: PCI\VEN_8086&DEV_0412&SUBSYS_21F5103C&REV_06\3&11583659&0&10
   Driver: C:\WINDOWS\system32\DRIVERS\igdkmd64.sys, 20.19.0015.4835 (English), 12/22/2017 01:22:16, 7972296 bytes
   Driver: C:\WINDOWS\system32\igd10iumd64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:16, 16451000 bytes
   Driver: C:\WINDOWS\system32\igd10idpp64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:10, 312264 bytes
   Driver: C:\WINDOWS\system32\igd11dxva64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:20, 33471440 bytes
   Driver: C:\WINDOWS\system32\igd12umd64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:26, 4268488 bytes
   Driver: C:\WINDOWS\system32\igdumdim64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:44, 39861272 bytes
   Driver: C:\WINDOWS\system32\igdail64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:58, 192992 bytes
   Driver: C:\WINDOWS\system32\igfxcmrt64.dll, 5.00.0000.1148 (English), 12/22/2017 01:22:06, 183944 bytes
   Driver: C:\WINDOWS\system32\igfx11cmrt64.dll, 5.00.0000.1148 (English), 12/22/2017 01:21:58, 182920 bytes
   Driver: C:\WINDOWS\system32\igfxcmjit64.dll, 5.00.0000.1148 (English), 12/22/2017 01:22:40, 1590752 bytes
   Driver: C:\WINDOWS\system32\igdde64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:34, 222696 bytes
   Driver: C:\WINDOWS\system32\IntelCpHDCPSvc.exe, 1.00.0000.0001 (English), 12/22/2017 01:24:08, 448968 bytes
   Driver: C:\WINDOWS\system32\igdusc64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:48, 6693112 bytes
   Driver: C:\WINDOWS\system32\igc64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:00, 15477944 bytes
   Driver: C:\WINDOWS\system32\igdmd64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:40, 2393128 bytes
   Driver: C:\WINDOWS\SysWow64\igd10iumd32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:10, 13062744 bytes
   Driver: C:\WINDOWS\SysWow64\igd10idpp32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:04, 297128 bytes
   Driver: C:\WINDOWS\SysWow64\igd11dxva32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:18, 34824440 bytes
   Driver: C:\WINDOWS\SysWow64\igd12umd32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:22, 4240176 bytes
   Driver: C:\WINDOWS\SysWow64\igdumdim32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:40, 38903864 bytes
   Driver: C:\WINDOWS\SysWow64\igdail32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:54, 173536 bytes
   Driver: C:\WINDOWS\SysWow64\igdde32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:30, 181792 bytes
   Driver: C:\WINDOWS\SysWow64\igfxcmrt32.dll, 5.00.0000.1148 (English), 12/22/2017 01:22:02, 160232 bytes
   Driver: C:\WINDOWS\SysWow64\igfx11cmrt32.dll, 5.00.0000.1148 (English), 12/22/2017 01:21:54, 160232 bytes
   Driver: C:\WINDOWS\SysWow64\igfxcmjit32.dll, 5.00.0000.1148 (English), 12/22/2017 01:22:36, 1178592 bytes
   Driver: C:\WINDOWS\SysWow64\igdusc32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:48, 5137776 bytes
   Driver: C:\WINDOWS\SysWow64\igc32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:00, 13483160 bytes
   Driver: C:\WINDOWS\SysWow64\igdmd32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:34, 1858600 bytes
   Driver: C:\WINDOWS\SysWow64\iglhcp32.dll, 3.00.0001.0026 (English), 12/22/2017 01:22:16, 205320 bytes
   Driver: C:\WINDOWS\SysWow64\iglhsip32.dll, 9.00.0030.9000 (English), 12/22/2017 01:22:26, 1814024 bytes
   Driver: C:\WINDOWS\SysWow64\IntelCpHeciSvc.exe, 9.00.0018.0917 (English), 12/22/2017 01:24:12, 502720 bytes
   Driver: C:\WINDOWS\system32\iglhxs64.vp, 12/22/2017 01:09:48, 4862 bytes
   Driver: C:\WINDOWS\system32\iglhxo64.vp, 12/22/2017 01:09:48, 40343 bytes
   Driver: C:\WINDOWS\system32\iglhxc64.vp, 12/22/2017 01:09:48, 40316 bytes
   Driver: C:\WINDOWS\system32\iglhxg64.vp, 12/22/2017 01:09:48, 39658 bytes
   Driver: C:\WINDOWS\system32\iglhxo64_dev.vp, 12/22/2017 01:09:48, 40931 bytes
   Driver: C:\WINDOWS\system32\iglhxc64_dev.vp, 12/22/2017 01:09:48, 41296 bytes
   Driver: C:\WINDOWS\system32\iglhxg64_dev.vp, 12/22/2017 01:09:48, 39798 bytes
   Driver: C:\WINDOWS\system32\iglhxa64.vp, 12/22/2017 01:09:48, 1125 bytes
   Driver: C:\WINDOWS\system32\iglhxa64.cpa, 12/22/2017 01:09:48, 2813952 bytes
   Driver: C:\WINDOWS\system32\iglhcp64.dll, 3.00.0001.0026 (English), 12/22/2017 01:22:20, 242112 bytes
   Driver: C:\WINDOWS\system32\iglhsip64.dll, 9.00.0030.9000 (English), 12/22/2017 01:22:30, 1816680 bytes
   Driver: C:\WINDOWS\system32\cp_resources.bin, 12/22/2017 01:09:44, 511260 bytes
   Driver: C:\WINDOWS\system32\difx64.exe, 1.04.0004.0000 (English), 12/22/2017 01:21:08, 175552 bytes
   Driver: C:\WINDOWS\system32\igfxDH.dll, 6.15.0010.4835 (English), 12/22/2017 01:22:52, 755168 bytes
   Driver: C:\WINDOWS\system32\igfxDHLib.dll, 1.00.0000.0000 (Invariant Language), 12/22/2017 01:22:56, 84960 bytes
   Driver: C:\WINDOWS\system32\igfxDHLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 12/22/2017 01:22:58, 95200 bytes
   Driver: C:\WINDOWS\system32\igfxDI.dll, 6.15.0010.4835 (English), 12/22/2017 01:23:02, 398304 bytes
   Driver: C:\WINDOWS\system32\igfxDILib.dll, 1.00.0000.0000 (Invariant Language), 12/22/2017 01:23:06, 29152 bytes
   Driver: C:\WINDOWS\system32\igfxDILibv2_0.dll, 1.00.0000.0000 (Invariant Language), 12/22/2017 01:23:06, 29152 bytes
   Driver: C:\WINDOWS\system32\igfxLHM.dll, 6.15.0010.4835 (English), 12/22/2017 01:23:34, 2141664 bytes
   Driver: C:\WINDOWS\system32\igfxLHMLib.dll, 1.00.0000.0000 (Invariant Language), 12/22/2017 01:23:38, 22496 bytes
   Driver: C:\WINDOWS\system32\igfxLHMLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 12/22/2017 01:23:44, 22496 bytes
   Driver: C:\WINDOWS\system32\igfxSDK.exe, 12/22/2017 01:23:48, 1023944 bytes
   Driver: C:\WINDOWS\system32\igfxSDKLib.dll, 1.00.0000.0000 (Invariant Language), 12/22/2017 01:23:48, 100832 bytes
   Driver: C:\WINDOWS\system32\igfxSDKLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 12/22/2017 01:23:54, 111584 bytes
   Driver: C:\WINDOWS\system32\igfxEM.exe, 6.15.0010.4835 (English), 12/22/2017 01:23:16, 354248 bytes
   Driver: C:\WINDOWS\system32\igfxEMLib.dll, 1.00.0000.0000 (Invariant Language), 12/22/2017 01:23:20, 27616 bytes
   Driver: C:\WINDOWS\system32\igfxEMLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 12/22/2017 01:23:20, 27616 bytes
   Driver: C:\WINDOWS\system32\GfxUIEx.exe, 6.15.0010.4835 (English), 12/22/2017 01:21:22, 466880 bytes
   Driver: C:\WINDOWS\system32\Gfxv4_0.exe, 8.15.0010.4835 (French), 12/22/2017 01:21:32, 968128 bytes
   Driver: C:\WINDOWS\system32\Gfxv4_0.exe.config, 12/22/2017 01:09:44, 935 bytes
   Driver: C:\WINDOWS\system32\Gfxv2_0.exe, 8.15.0010.4835 (French), 12/22/2017 01:21:28, 964544 bytes
   Driver: C:\WINDOWS\system32\Gfxv2_0.exe.config, 12/22/2017 01:09:44, 895 bytes
   Driver: C:\WINDOWS\system32\GfxResources.dll, 8.15.0010.4835 (French), 12/22/2017 01:21:18, 5262808 bytes
   Driver: C:\WINDOWS\system32\MetroIntelGenericUIFramework.dll, 1.00.0000.0000 (French), 12/22/2017 01:25:20, 704992 bytes
   Driver: C:\WINDOWS\system32\igfxCUIServicePS.dll, 12/22/2017 01:22:48, 103392 bytes
   Driver: C:\WINDOWS\system32\igfxCUIService.exe, 6.15.0010.4835 (English), 12/22/2017 01:22:44, 373704 bytes
   Driver: C:\WINDOWS\system32\igfxCPL.cpl, 12/22/2017 01:22:44, 273376 bytes
   Driver: C:\WINDOWS\system32\igfxTray.exe, 12/22/2017 01:23:58, 401864 bytes
   Driver: C:\WINDOWS\system32\igfxDTCM.dll, 6.15.0010.4835 (English), 12/22/2017 01:23:10, 254944 bytes
   Driver: C:\WINDOWS\system32\igfxHK.exe, 6.15.0010.4835 (English), 12/22/2017 01:23:34, 268224 bytes
   Driver: C:\WINDOWS\system32\igfxOSP.dll, 6.15.0010.4835 (English), 12/22/2017 01:23:44, 389600 bytes
   Driver: C:\WINDOWS\system32\DPTopologyApp.exe, 8.15.0010.4835 (French), 12/22/2017 01:21:12, 232384 bytes
   Driver: C:\WINDOWS\system32\DPTopologyApp.exe.config, 12/22/2017 01:09:44, 935 bytes
   Driver: C:\WINDOWS\system32\DPTopologyAppv2_0.exe, 8.15.0010.4835 (French), 12/22/2017 01:21:14, 231872 bytes
   Driver: C:\WINDOWS\system32\DPTopologyAppv2_0.exe.config, 12/22/2017 01:09:44, 895 bytes
   Driver: C:\WINDOWS\system32\igfxext.exe, 6.15.0010.4835 (English), 12/22/2017 01:23:30, 236488 bytes
   Driver: C:\WINDOWS\system32\igfxexps.dll, 6.15.0010.4835 (English), 12/22/2017 01:22:12, 55200 bytes
   Driver: C:\WINDOWS\system32\ColorImageEnhancement.wmv, 12/22/2017 01:09:44, 375173 bytes
   Driver: C:\WINDOWS\system32\ImageStabilization.wmv, 12/22/2017 01:09:48, 403671 bytes
   Driver: C:\WINDOWS\system32\FilmModeDetection.wmv, 12/22/2017 01:09:44, 641530 bytes
   Driver: C:\WINDOWS\SysWow64\igfxexps32.dll, 6.15.0010.4835 (English), 12/22/2017 01:23:26, 52704 bytes
   Driver: C:\WINDOWS\system32\ig75icd64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:40, 11748312 bytes
   Driver: C:\WINDOWS\SysWow64\ig75icd32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:36, 8734680 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\llvm_release_license.txt, 12/22/2017 01:09:48, 1981 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\readme.txt, 12/22/2017 01:09:48, 9788 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\version.ini, 12/22/2017 01:09:48, 34 bytes
   Driver: C:\WINDOWS\SysWow64\Intel_OpenCL_ICD32.dll, 2.00.0002.0000 (English), 12/22/2017 01:25:10, 103904 bytes
   Driver: C:\WINDOWS\SysWow64\IntelOpenCL32.dll, 20.19.0015.4835 (English), 12/22/2017 01:24:16, 318432 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\task_executor32.dll, 5.02.0000.10094 (English), 12/22/2017 01:26:50, 373216 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\OclCpuBackend32.dll, 5.02.0000.10094 (English), 12/22/2017 01:26:44, 7126496 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\intelocl32.dll, 5.02.0000.10094 (English), 12/22/2017 01:26:34, 1408480 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\cpu_device32.dll, 5.02.0000.10094 (English), 12/22/2017 01:26:26, 522720 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8.rtl, 12/22/2017 01:09:48, 1223604 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8_img_cbk.o, 12/22/2017 01:09:48, 296664 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8_img_cbk.rtl, 12/22/2017 01:09:48, 389300 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9.rtl, 12/22/2017 01:09:48, 1157132 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9_img_cbk.o, 12/22/2017 01:09:48, 287436 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9_img_cbk.rtl, 12/22/2017 01:09:48, 389180 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9.rtl, 12/22/2017 01:09:48, 785172 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9_img_cbk.o, 12/22/2017 01:09:48, 249992 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9_img_cbk.rtl, 12/22/2017 01:09:48, 350952 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clang_compiler32.dll, 5.02.0000.10094 (English), 12/22/2017 01:26:16, 242656 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_n8.dll, 3.04.0000.0000 (English), 12/22/2017 01:27:26, 5022688 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_g9.dll, 3.04.0000.0000 (English), 12/22/2017 01:27:20, 5360096 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_s9.dll, 3.04.0000.0000 (English), 12/22/2017 01:27:30, 5238240 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbbmalloc.dll, 4.02.2014.0601 (French), 12/22/2017 01:27:06, 208504 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbb.dll, 4.02.2014.0601 (French), 12/22/2017 01:26:58, 360056 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbb_preview.dll, 4.02.2013.1002 (), 12/22/2017 01:27:10, 355960 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\common\clbltfnshared.rtl, 12/22/2017 01:09:48, 1026520 bytes
   Driver: C:\WINDOWS\system32\Intel_OpenCL_ICD64.dll, 2.00.0002.0000 (English), 12/22/2017 01:25:16, 99808 bytes
   Driver: C:\WINDOWS\system32\IntelOpenCL64.dll, 20.19.0015.4835 (English), 12/22/2017 01:24:20, 416224 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\task_executor64.dll, 5.02.0000.10094 (English), 12/22/2017 01:26:54, 428512 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\OclCpuBackend64.dll, 5.02.0000.10094 (English), 12/22/2017 01:26:44, 9629152 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\intelocl64.dll, 5.02.0000.10094 (English), 12/22/2017 01:26:34, 1628128 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\cpu_device64.dll, 5.02.0000.10094 (English), 12/22/2017 01:26:30, 669152 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8.rtl, 12/22/2017 01:09:48, 1226660 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8_img_cbk.o, 12/22/2017 01:09:48, 358288 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8_img_cbk.rtl, 12/22/2017 01:09:48, 402580 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9.rtl, 12/22/2017 01:09:48, 1159784 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9_img_cbk.o, 12/22/2017 01:09:48, 347104 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9_img_cbk.rtl, 12/22/2017 01:09:48, 402468 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9.rtl, 12/22/2017 01:09:48, 788292 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9_img_cbk.o, 12/22/2017 01:09:48, 294032 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9_img_cbk.rtl, 12/22/2017 01:09:48, 364424 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clang_compiler64.dll, 5.02.0000.10094 (English), 12/22/2017 01:26:20, 267744 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_h8.dll, 3.04.0000.0000 (English), 12/22/2017 01:27:22, 5234144 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_e9.dll, 3.04.0000.0000 (English), 12/22/2017 01:27:16, 5744608 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_l9.dll, 3.04.0000.0000 (English), 12/22/2017 01:27:26, 5627360 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbbmalloc.dll, 4.02.2014.0601 (French), 12/22/2017 01:27:10, 248440 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbb.dll, 4.02.2014.0601 (French), 12/22/2017 01:27:02, 438392 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbb_preview.dll, 4.02.2013.1002 (), 12/22/2017 01:27:16, 433784 bytes
   Driver: C:\WINDOWS\SysWow64\igdbcl32.dll, 20.19.0015.4835 (English), 12/22/2017 01:22:02, 388576 bytes
   Driver: C:\WINDOWS\SysWow64\igdrcl32.dll, 20.19.0015.4835 (English), 12/22/2017 01:22:30, 4368864 bytes
   Driver: C:\WINDOWS\SysWow64\common_clang32.dll, 4.00.0000.0000 (English), 12/22/2017 01:20:58, 19861472 bytes
   Driver: C:\WINDOWS\SysWow64\igdmcl32.dll, 20.19.0015.4835 (English), 12/22/2017 01:22:26, 3972064 bytes
   Driver: C:\WINDOWS\SysWow64\igdfcl32.dll, 20.19.0015.4835 (English), 12/22/2017 01:22:12, 225248 bytes
   Driver: C:\WINDOWS\system32\igdbcl64.dll, 20.19.0015.4835 (English), 12/22/2017 01:22:06, 438752 bytes
   Driver: C:\WINDOWS\system32\igdrcl64.dll, 20.19.0015.4835 (English), 12/22/2017 01:22:30, 4931040 bytes
   Driver: C:\WINDOWS\system32\common_clang64.dll, 4.00.0000.0000 (English), 12/22/2017 01:21:02, 29101528 bytes
   Driver: C:\WINDOWS\system32\igdmcl64.dll, 20.19.0015.4835 (English), 12/22/2017 01:22:26, 5683680 bytes
   Driver: C:\WINDOWS\system32\igdfcl64.dll, 20.19.0015.4835 (English), 12/22/2017 01:22:16, 266208 bytes
   Driver: C:\WINDOWS\system32\igdclbif.bin, 12/22/2017 01:09:46, 5799386 bytes
   Driver: C:\Program Files\Intel\Media SDK\libmfxhw32.dll, 7.16.0010.0020 (English), 12/22/2017 01:22:34, 8872552 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfxplugin32_hw.dll, 1.16.0010.0020 (English), 12/22/2017 01:25:24, 4741296 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h264ve_32.dll, 7.16.0010.0020 (English), 12/22/2017 01:22:38, 1457096 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_mjpgvd_32.dll, 7.16.0010.0020 (English), 12/22/2017 01:25:38, 1350320 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp8vd_32.dll, 7.16.0010.0020 (English), 12/22/2017 01:26:02, 1358512 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp9vd_32.dll, 7.16.0010.0020 (English), 12/22/2017 01:26:06, 1358512 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h265ve_32.dll, 7.16.0010.0020 (English), 12/22/2017 01:22:44, 1471392 bytes
   Driver: C:\Program Files\Intel\Media SDK\h265e_32.vp, 12/22/2017 01:09:44, 63761 bytes
   Driver: C:\Program Files\Intel\Media SDK\he_32.vp, 12/22/2017 01:09:44, 62217 bytes
   Driver: C:\Program Files\Intel\Media SDK\c_32.cpa, 12/22/2017 01:09:44, 846855 bytes
   Driver: C:\Program Files\Intel\Media SDK\cpa_32.vp, 12/22/2017 01:09:44, 993 bytes
   Driver: C:\Program Files\Intel\Media SDK\dev_32.vp, 12/22/2017 01:09:44, 21523 bytes
   Driver: C:\Program Files\Intel\Media SDK\mj_32.vp, 12/22/2017 01:09:48, 57541 bytes
   Driver: C:\Program Files\Intel\Media SDK\libmfxhw64.dll, 7.16.0010.0020 (English), 12/22/2017 01:22:34, 9318344 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfxplugin64_hw.dll, 1.16.0010.0020 (English), 12/22/2017 01:25:24, 4919472 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h264ve_64.dll, 7.16.0010.0020 (English), 12/22/2017 01:22:44, 1810856 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_mjpgvd_64.dll, 7.16.0010.0020 (English), 12/22/2017 01:25:44, 1677488 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp8vd_64.dll, 7.16.0010.0020 (English), 12/22/2017 01:26:02, 1686192 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp9vd_64.dll, 7.16.0010.0020 (English), 12/22/2017 01:26:06, 1687216 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h265ve_64.dll, 7.16.0010.0020 (English), 12/22/2017 01:22:48, 1836712 bytes
   Driver: C:\Program Files\Intel\Media SDK\h265e_64.vp, 12/22/2017 01:09:44, 13485 bytes
   Driver: C:\Program Files\Intel\Media SDK\he_64.vp, 12/22/2017 01:09:44, 12873 bytes
   Driver: C:\Program Files\Intel\Media SDK\c_64.cpa, 12/22/2017 01:09:44, 1519616 bytes
   Driver: C:\Program Files\Intel\Media SDK\cpa_64.vp, 12/22/2017 01:09:44, 993 bytes
   Driver: C:\Program Files\Intel\Media SDK\dev_64.vp, 12/22/2017 01:09:44, 21523 bytes
   Driver: C:\Program Files\Intel\Media SDK\mj_64.vp, 12/22/2017 01:09:48, 12365 bytes
   Driver: C:\WINDOWS\system32\igfxCoIn_v4835.dll, 1.03.0025.0000 (English), 12/22/2017 01:24:02, 234976 bytes
   Driver: C:\WINDOWS\system32\DisplayAudiox64.cab, 12/22/2017 01:09:44, 831685 bytes
     Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_8CBA&SUBSYS_21F5103C&REV_00\3&11583659&0&B0
   Driver: C:\WINDOWS\system32\DRIVERS\TeeDriverx64.sys, 10.00.0030.1054 (English), 9/30/2014 17:47:28, 129312 bytes
   Driver: C:\ProgramData\Microsoft\Windows\DeviceMetadataStore\EN\3f3ca95b-3978-4168-b47b-5444f42d6c89.devicemetadata-ms, 9/30/2014 17:47:28, 938 bytes
   Driver: C:\ProgramData\Microsoft\Windows\DeviceMetadataStore\EN\46a6fdbe-c823-4579-bab6-35f67e01f793.devicemetadata-ms, 9/30/2014 17:47:28, 833 bytes
   Driver: C:\WINDOWS\system32\WdfCoInstaller01011.dll, 1.11.9200.16384 (French), 3/4/2015 22:08:20, 1795952 bytes
     Name: Contrôleur hôte Intel(R) USB 3.0 eXtensible - 1.0 (Microsoft)
Device ID: PCI\VEN_8086&DEV_8CB1&SUBSYS_21F5103C&REV_00\3&11583659&0&A0
   Driver: C:\WINDOWS\system32\DRIVERS\USBXHCI.SYS, 10.00.17134.0001 (French), 4/12/2018 00:33:52, 434592 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\UMDF\UsbXhciCompanion.dll, 10.00.17134.0001 (English), 4/12/2018 00:33:52, 123576 bytes
     Name: Contrôleur High Definition Audio
Device ID: PCI\VEN_8086&DEV_8CA0&SUBSYS_21F5103C&REV_00\3&11583659&0&D8
   Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 10.00.17134.0001 (English), 4/12/2018 00:33:45, 86016 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\drmk.sys, 10.00.17134.0001 (English), 4/12/2018 00:33:46, 98304 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\portcls.sys, 10.00.17134.0001 (English), 4/12/2018 00:33:46, 379392 bytes
     Name: Intel(R) 9 Series Chipset Family PCI Express Root Port 3 - 8C94
Device ID: PCI\VEN_8086&DEV_8C94&SUBSYS_21F5103C&REV_D0\3&11583659&0&E2
Device ID: PCI\VEN_8086&DEV_8CA6&SUBSYS_21F5103C&REV_00\3&11583659&0&E8
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.17134.0001
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.17134.0001
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.17134.0001
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.17134.0001
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.17134.0001
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.17134.0001
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.17134.0471
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.17134.0001
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.17134.0001
DV Muxer,0x00400000,0,0,qdv.dll,10.00.17134.0001
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.17134.0001
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.17134.0001
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.17134.0001
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.17134.0001
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.17134.0001
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.17134.0471
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.17134.0001
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.17134.0001
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.17134.0001
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.17134.0001
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.17134.0001
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.17134.0001
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.17134.0001
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.17134.0001
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.17134.0001
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.17134.0112
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.17134.0001
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.17134.0001
DV Splitter,0x00600000,1,2,qdv.dll,10.00.17134.0001
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.17134.0001
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.17134.0112
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.17134.0001
Video Renderer,0x00800001,1,0,quartz.dll,10.00.17134.0001
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.17134.0001
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.17134.0001
Video Renderer,0x00400000,1,0,quartz.dll,10.00.17134.0001
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.17134.0001
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.17134.0001
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.17134.0001
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.17134.0001
Overlay Mixer2,0x00200000,1,1,,
AVI Draw,0x00600064,9,1,quartz.dll,10.00.17134.0001
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.17134.0112
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.17134.0001
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.17134.0001
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.17134.0001
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.17134.0001
Null Renderer,0x00200000,1,0,qedit.dll,10.00.17134.0001
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.17134.0001
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.17134.0001
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.17134.0001
Smart Tee,0x00200000,1,2,qcap.dll,10.00.17134.0001
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.17134.0001
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.17134.0001
Wave Parser,0x00400000,1,1,quartz.dll,10.00.17134.0001
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.17134.0001
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.17134.0001
File stream renderer,0x00400000,1,1,quartz.dll,10.00.17134.0001
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.17134.0471
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.17134.0001
AVI Mux,0x00200000,1,0,qcap.dll,10.00.17134.0001
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.17134.0001
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.17134.0001
File Source (URL),0x00400000,0,1,quartz.dll,10.00.17134.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.17134.0001
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.17134.0320
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.17134.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.17134.0001
WDM Streaming Tee/Splitter Devices:
Convertisseur en T/site-à-site,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.17134.0001
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.17134.0001
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.17134.0001
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.17134.0001
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.17134.0001
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.17134.0001
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.17134.0001
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.17134.0001
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.17134.0001
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.17134.0001
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.17134.0001
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.17134.0001
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.17134.0001
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.17134.0441
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.17134.0441
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.17134.0441
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.17134.0001
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.17134.0001
WDM Streaming Capture Devices:
Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.17134.0001
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.17134.0001
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.17134.0001
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.17134.0001
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.17134.0001
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.17134.0001
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.17134.0001
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,msvidctl.dll,6.05.17134.0001
Encrypt/Tag,0x00200000,0,0,,
PTFilter,0x00200000,0,0,,
XDS Codec,0x00200000,0,0,,
WDM Streaming Communication Transforms:
Audio Renderers:
Haut-parleurs (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.17134.0001
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.17134.0001
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.17134.0001
DirectSound: Haut-parleurs (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.17134.0001
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
  <transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
  Intel® Hardware M-JPEG Decoder MFT, {00C69F81-0524-48C0-A353-4DD9D54F9A6E}, 0x6, 7, mfx_mft_mjpgvd_64.dll, 7.16.0010.0020
  Intel® Hardware VP8 Decoder MFT, {6D856398-834E-4A89-8EE5-071BB3F58BE4}, 0x6, mfx_mft_vp8vd_64.dll, 7.16.0010.0020
  Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.17134.0471
  DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.17134.0001
  Intel® Hardware VP8 Sync Decoder MFT, {451E3CB7-2622-4BA5-8E1D-44B3C41D0924}, 0x1, mfx_mft_vp8vd_64.dll, 7.16.0010.0020
  Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.17134.0001
  Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.17134.0471
  WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.17134.0001
  WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.17134.0471
  MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.17134.0001
  Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.17134.0001
  Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}, 0x1, MSVP9DEC.dll, 10.00.17134.0471
  Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.17134.0001
  HEVCVideoExtension
Video Encoders:
  Intel® Quick Sync Video H.264 Encoder MFT, {4BE8D3C0-0515-4A37-AD55-E4BAE19AF471}, 0x4, 7, mfx_mft_h264ve_64.dll, 7.16.0010.0020
  H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.17134.0001
  WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.17134.0001
  Microsoft MF VPX Encoder Transform, {AEB6C755-2546-4881-82CC-E15AE5EBFF3D}, 0x1, MSVPXENC.dll, 10.00.17134.0471
  H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.17134.0001
  WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.17134.0001
  Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.17134.0112
  HEVCVideoExtensionEncoder
Video Effects:
  Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.17134.0001
  Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.17134.0001
  VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.17134.0407
  Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.17134.0001
  Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.17134.0001
Video Processor:
  Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.17134.0376
Audio Decoders:
  Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.17134.0081
  MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.17134.0001
  WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.17134.0001
  Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.17134.0471
  A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.17134.0471
  GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.17134.0471
  WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.17134.0001
  Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.17134.0001
  Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.17134.0001
  Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.17134.0471
  WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.17134.0001
  G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.17134.0471
  IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.17134.0471
  MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.17134.0001
  Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.17134.0001
  ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.17134.0471
  Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.17134.0001
  DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.17134.0001
Audio Encoders:
  LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.17134.0001
  MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.17134.0471
  Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.17134.0001
  WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.17134.0001
  MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.17134.0001
  Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.17134.0112
  WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.17134.0001
  Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.17134.0001
  Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.17134.0001
  Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.17134.0001
Audio Effects:
  AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.17134.0001
  Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.17134.0137
Multiplexers:
  Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.17134.0407
Others:
  Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.17134.0471
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableEncoders = 1
EnableDecoders = 1
EnableVideoProcessors = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.weba, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
{A61AC364-AD0E-4744-89FF-213CE0DF8804}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{30395056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
{30385056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
  Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
  Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
  PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Détecteur d'erreurs 1891846930211596104, type 5
Nom d’événement : RADAR_PRE_LEAK_WOW64
Réponse : Non disponible
ID de CAB : 0
Signature du problème :
P1 : devenv.exe
P2 : 15.8.28010.2026
P3 : 10.0.17134.2.0.0
P4 :
P5 :
P6 :
P7 :
P8 :
P9 :
P10 :
Fichiers joints :
\\?\C:\Users\JCBER_~1\AppData\Local\Temp\RDR142.tmp\empty.txt
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER143.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER154.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER17E.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER19E.tmp.txt
Ces fichiers sont peut-être disponibles ici :
Symbole d’analyse :
Nouvelle recherche de la solution : 0
ID de rapport : 3edda694-0969-4550-8f91-f0955720c485
Statut du rapport : 268435456
Récipient avec hachage : 7697688c2fbc89ddca4130c274ace748
GUID CAB :0
+++ WER1 +++:
Détecteur d'erreurs 1474374509742358388, type 5
ID de CAB : 0
P1 : EauPro.App.WPF.exe
P2 : 3.0.0.0
P4 :
P5 :
P6 :
P7 :
P8 :
P9 :
P10 :
Fichiers joints :
\\?\C:\Users\JCBER_~1\AppData\Local\Temp\RDRCCAA.tmp\empty.txt
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCCBA.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCCFA.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCD75.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCDF3.tmp.txt
Symbole d’analyse :
ID de rapport : 62a3d099-f222-4c06-b731-4b0a7c9b2e3f
Récipient avec hachage : 03d41908680f744a647607ce17157f74
GUID CAB :0
+++ WER2 +++:
Détecteur d'erreurs 2267079189276135810, type 1
Nom d’événement : APPCRASH
ID de CAB : 0
P2 : 3.0.0.0
P3 : 5c0e20a1
P4 : KERNELBASE.dll
P5 : 10.0.17134.407
P6 : ade8d4fe
P7 : c0020001
P8 : 00111812
P9 :
P10 :
Fichiers joints :
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER2B0B.tmp.dmp
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3B0A.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3B2A.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3B28.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3B49.tmp.txt
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_EauPro.App.WPF.e_35e85e75b298565c2f838c69f155cde1f273ce_3944f24b_5d334942
Symbole d’analyse :
ID de rapport : ce0c7ff2-fe8f-42b1-9c6b-f34ba87c5404
Récipient avec hachage : e3f5b2f33831200a2f764882da7c1182
GUID CAB :0
+++ WER3 +++:
Détecteur d'erreurs 1282635736330599100, type 5
ID de CAB : 0
P1 : Poseis.DbImport.exe
P2 : 1.0.0.0
P4 :
P5 :
P6 :
P7 :
P8 :
P9 :
P10 :
Fichiers joints :
\\?\C:\Users\JCBER_~1\AppData\Local\Temp\RDR9304.tmp\empty.txt
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER9314.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER9325.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER936E.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER939E.tmp.txt
Symbole d’analyse :
ID de rapport : 3727fc61-185f-4655-b6b1-bceeea3f1768
Récipient avec hachage : c2dbbeaa227c542691ccd6681034fabc
GUID CAB :0
+++ WER4 +++:
Détecteur d'erreurs 1553488786874201904, type 5
Nom d’événement : RADAR_PRE_LEAK_64
ID de CAB : 0
P1 : sqlservr.exe
P2 : 2014.120.2569.0
P4 :
P5 :
P6 :
P7 :
P8 :
P9 :
P10 :
Fichiers joints :
\\?\C:\Users\JCBER_~1\AppData\Local\Temp\RDR6BED.tmp\empty.txt
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6BFD.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6C0E.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6C79.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6CA9.tmp.txt
Symbole d’analyse :
ID de rapport : 3229de24-9a38-4c9e-9b6b-3cafe7e8bd18
Récipient avec hachage : c7470f0f5803cc9b358f19d228307730
GUID CAB :0
+++ WER5 +++:
Détecteur d'erreurs 125730739576, type 5
Nom d’événement : PerfWatsonVS12Data
ID de CAB : 0
P1 : PerfWatsonTcdb
P2 : 0
P3 : 0
P4 : 0
P5 : 0
P6 :
P7 :
P8 :
P9 :
P10 :
Fichiers joints :
\\?\C:\Users\jcber_000\AppData\Local\Temp\VSTelem.Out\201812070845_D16.0_16.0.28329.73_3144_10a9b079-de63-439d-a493-592007a91d94.tcdb
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCCB5.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCCC5.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCD01.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCD40.tmp.txt
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\NonCritical_PerfWatsonTcdb_688f135dd185f2a8133a474a2518efc6ce6cc4a_00000000_0ffcd212
Symbole d’analyse :
ID de rapport : 05910759-810c-4f62-be29-fcfc2ab3d070
Récipient avec hachage : fb30d2b9a7acf0305d4da51668259751
GUID CAB :0
+++ WER6 +++:
Détecteur d'erreurs , type 0
Nom d’événement : VisualStudioNonFatalErrors2
ID de CAB : 0
P1 : devenv.exe
P2 : 16.0.28329.73
P3 : vs.taskstatuscenter.task-completed-tip-fault
P4 : System.ArgumentNullException
P5 : Microsoft.VisualStudio.Shell.UI.Internal
P6 : Microsoft.Internal.VisualStudio.PlatformUI.Tipping.UIFactory.CreateCallout
P7 : _
P8 : _
P9 : _
P10 : _
Fichiers joints :
\\?\C:\Users\jcber_000\AppData\Local\Temp\VSFaultInfo\181207_083924_5401559\ErrorInformation.txt
Symbole d’analyse :
ID de rapport : 32323b36-02e3-4be0-a2ae-c26cab27f890
Statut du rapport : 268697600
GUID CAB :0
+++ WER7 +++:
Détecteur d'erreurs 1802750596775480438, type 5
ID de CAB : 0
P1 : devenv.exe
P2 : 16.0.28329.73
P7 : _
P8 : _
P9 : _
P10 : _
Fichiers joints :
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER7715.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER7745.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER7792.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER77D1.tmp.txt
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\NonCritical_devenv.exe_36a384ed35c49944456d4c7618f9e829efff962_00000000_39fc7d2f
Symbole d’analyse :
Récipient avec hachage : 08f3fad674efb9fab904a81dcb6d0c76
GUID CAB :0
+++ WER8 +++:
Détecteur d'erreurs 128015651019, type 5
ID de CAB : 0
P1 : PerfWatsonHang
P2 : 0
P3 : 0
P4 : 0
P5 : 0
P6 :
P7 :
P8 :
P9 :
P10 :
Fichiers joints :
\\?\C:\Users\jcber_000\AppData\Local\Temp\PerfWatsonHangDumpd4dcd77e-1971-4415-ac9d-4ae41fe0183e.dmp
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6E6B.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6E8B.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6F07.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6F37.tmp.txt
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\NonCritical_PerfWatsonHang_4228e14e66c54c31dfb740949c9862f77bc12_00000000_0c007679
Symbole d’analyse :
ID de rapport : bc676f08-8c48-4bb7-9e6c-bdf71fee38fb
Récipient avec hachage : bf24924e654075043ccbcccc8a4ddf6f
GUID CAB :0
+++ WER9 +++:
ID de CAB : 0
P1 : PerfWatsonTcdb
P2 : 0
P3 : 0
P4 : 0
P5 : 0
P6 :
P7 :
P8 :
P9 :
P10 :
Fichiers joints :
\\?\C:\Users\jcber_000\AppData\Local\Temp\VSTelem.Out\201812060839_D16.0_16.0.28329.73_13416_f9da370f-0e9e-40e2-b559-62849e1608e7.tcdb
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER1FBA.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER1FDB.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER2066.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER20B5.tmp.txt
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\NonCritical_PerfWatsonTcdb_688f135dd185f2a8133a474a2518efc6ce6cc4a_00000000_30562410
Symbole d’analyse :
ID de rapport : eaaaec4f-7e38-4e1c-812a-59041e1916cc
GUID CAB
