Slope Function keeps failing
2992
12-12-2018 02:28 PM
Labels (4)
NicoleKeller
Hello all,
I am trying to run the Slope tool on a DEM mosaic I have.  The original DEMs came from USGS and are in NAD UTM 1983. I have mosaiced them into a single dataset. I repeatedly get the dreaded Error 999999 when I run the Slope tool, but no messages indicating why. It fails as soon as it starts, even though my computer usually takes several moments to run a tool. Can anyone think of anything else I might be doing wrong here to cause the error?
Properties of DEM file
DanPatterson_Retired
are you using the raster function? or the raster tool in arctoolbox
Slope function—ArcGIS Pro | ArcGIS Desktop
Raster functions can be applied to mosaic datasets
Raster functions—ArcGIS Pro | ArcGIS Desktop  see the section
Functions can be applied to the following data types:
NicoleKeller
Thanks for replying, Dan.  Turns out, I just had to turn off background processing! I read in an article that can sometimes cause those spontaneous 999999 errors, and once I turned that off, my computer had no problem. SO WEIRD.
Go to know... now switch to ArcGIS Pro and you won't have to worry about 64bit
