Create Mobile Map Package Error: "Table not registered"
554
12-13-2018 07:17 AM
PaulBarth1
Create Mobile Map Package keeps failing for me, the error message says "Table not registered" for all of the standard layers that come with StreetMap Premium for Custom Roads. I tried swapping out all of them from my Pro project with the same layers from the original Pro project, but that didn't work either. Can someone point me in the right direction about how to fix this? Here is my error message:
ERROR 999999: Error executing function.
Table not registered [main.WaterAreas_g5_591m]
Table not registered [main.WaterAreas_g5_18m]
Table not registered [main.WaterAreas_g4_15m]
Table not registered [main.WaterAreas_g4_4m]
Table not registered [main.WaterAreas_g3_1m]
Table not registered [main.WaterAreas_g3_577k]
Table not registered [main.WaterAreas_g2_288k]
Table not registered [main.WaterAreas_g1_72k]
Table not registered [main.Oceans_g5_591m_labels]
Table not registered [main.Oceans_g5_591m]
Table not registered [main.Oceans_g4_15m]
Table not registered [main.Oceans_g3_1m]
Table not registered [main.Oceans_g2_288k]
Table not registered [main.Oceans_g1_72k]
Table not registered [main.Admin1Lines_g4_15m]
Table not registered [main.Admin1Lines_g3_1m]
Table not registered [main.Admin1Lines_g5_591m]
Table not registered [main.Islands_g1_72k]
Table not registered [main.Islands_g2_288k]
Table not registered [main.Islands_g3_1m]
Table not registered [main.Islands_g4_15m]
Table not registered [main.PopulatedPlaces_36k]
Table not registered [main.PopulatedPlaces_72k]
Table not registered [main.PopulatedPlaces_577k]
Table not registered [main.PopulatedPlaces_9m]
Table not registered [main.PopulatedPlaces_147m]
Table not registered [main.AdminArea0_100m_centroids]
Table not registered [main.Admin2Lines_g1_144k]
Table not registered [main.Admin2Lines_g3_577k]
Table not registered [main.Admin2Lines_g3_577k_labels]
Table not registered [main.Admin2Lines_g2_288k_labels]
Table not registered [main.Admin2Lines_g2_288k]
Table not registered [main.Exits_18k_labels]
Table not registered [main.Landuse_FacilityAreas_g5_591m]
Table not registered [main.Landuse_FacilityAreas_g4_15m]
Table not registered [main.Landuse_FacilityAreas_g3_1m]
Table not registered [main.Landuse_FacilityAreas_g2_288k]
Table not registered [main.Landuse_FacilityAreas_g1_72k]
Table not registered [main.Addresses_1k_labels]
Table not registered [main.AdminArea1_g4_15m]
Table not registered [main.AdminArea1_g5_591m]
Table not registered [main.AdminArea1_100m_centroids]
Table not registered [main.Motorways_g4_15m]
Table not registered [main.Motorways_g5_18m]
Table not registered [main.Highways_g4_4m]
Table not registered [main.Highways_g4_4m_labels]
Table not registered [main.UrbanAreas_g4_9m]
Table not registered [main.UrbanAreas_g3_1m]
Table not registered [main.UrbanAreas_g2_288k]
Table not registered [main.MajorRoads_g3_1m]
Table not registered [main.MajorRoads_g3_1m_labels]
Table not registered [main.MajorRoads_g3_577k]
Table not registered [main.MajorRoads_g3_577k_labels]
Table not registered [main.Railroads_g1_72k]
Table not registered [main.BuildingFootprints_g1_9k_borders]
Table not registered [main.BuildingFootprints_g1_9k]
Table not registered [main.BuildingFootprints_g1_9k_labels]
Table not registered [main.BuildingFootprints_g1_4k]
Table not registered [main.BuildingFootprints_g1_18k_borders]
Table not registered [main.BuildingFootprints_g1_18k]
Table not registered [main.BuildingFootprints_g1_18k_labels]
Table not registered [main.WaterLines_g1_72k]
Table not registered [main.OneWayArrows_g1_2k]
Table not registered [main.AdminArea2_g1_36k]
Table not registered [main.AdminArea2_g2_288k]
Table not registered [main.AdminArea2_g3_1m]
Table not registered [main.Streets_g1_72k_labels]
Table not registered [main.Streets_g2_144k_labels]
Table not registered [main.Streets_g2_288k]
Table not registered [main.Streets_g2_288k_labels]
Table not registered [main.Streets_g2_144k_tunnels]
Table not registered [main.Streets_g2_144k]
Table not registered [main.Streets_g1_72k_tunnels]
Table not registered [main.Streets_g1_72k]
Table not registered [main.Streets_g1_36k_tunnels]
Table not registered [main.Streets_g1_36k]
Table not registered [main.Streets_g1_36k_labels_all]
Table not registered [main.POI_9k]
Table not registered [main.POI_2k]
Table not registered [main.POI_9m]
Table not registered [main.POI_4k]
Table not registered [main.POI_288k]
Table not registered [main.POI_1k]
Failed to execute (CreateMobileMapPackage).
MarkBockenhauer
Hi Paul,
I don't know precisely what would cause this error, but it would appear that  you are re-packing a mobile map package?  "main." featureclass in the error message would appear to be the content of an MMPK.
When you Create Mobile Map packages from the original Pro project, does that work?
Re-packaging packages should not be a problem, but you mentioned that you swapped out the layers... how did you swap them out?
Mark
