problems using infographic widget
467
12-13-2018 01:42 AM
AntonioFraga1
Hí!,
I am using the infographic widget in an application but it doesn´t work as i expected. I am using the pie chart template, with  3 different fields.  it seems work fine if I select the option "select by extension" (the chart data changes depending on the extension), but if use "use selection"  the chart allways shows data for the whole dataset instead of the selected feature.
Best regards,
Antonio
