target server is not licensed for publishing
5534
12
12-12-2018 07:21 AM
ToddFagin
Occasional Contributor II
We recently setup ArcGIS Server 10.6 (on a Windows 2012 R2 VM). I am trying to publish a service from ArcMap 10.6, but receive the following message: "The selected target server is not licensed for publishing the current service type." This happens immediately upon selecting the connection in the Publish a Service dialog window. The best we can tell, the server is properly configured and licensed.
Any insight would be greatly appreciated.
Error_message
George_Thompson
Esri Frequent Contributor
Ah, you need to also license that site for ArcGIS Enterprise Advanced license. That license is required on the machine for publishing.
--- George T.
George_Thompson
What type of data are you trying to publish?
--- George T.
ToddFagin
Originally, I started with a simple vector point shapefile that I was going to publish as a feature service. Next, I tried a simple orthomosaic I was going to publish as a cached map service (tile layer). In both instances, I couldn't even get beyond the initial dialog window.
George_Thompson
Can you publish as a simple map service?
What level of licencing (Basic, Standard, Advanced) is your ArcGIS Server?
--- George T.
ToddFagin
I cannot get past the first dialog window to even select the type of service I wish to publish.
We have Advanced.
Thank you.
George_Thompson
This is normally seems to be related to licensing issues. Can you provide a screen shot of the following: Server Manager page > Site > Software Authorization
Otherwise a quick call into tech support may help you get up and running.
--- George T.
ToddFagin
Thanks for your assistance. Our system administrator seems to think ArcMap is looking for server resources that are not installed on my local machine and that installing Portal on the server will fix this. Then again, there may be additional licensing issues. Here's the screenshot.
authorization
George_Thompson
--- George T.
ToddFagin
That appears to have done the trick. Thanks again.
by Anonymous User
Not applicable
I am having the same issue, getting the error while publishing the feature services on portal "The selected target server is not licensed for publishing the current service type" .
We have ArcGIS Enterprise Advanced license as shown in the screen shot. Any idea how to fix this?
Thanks in advance.
