AnsweredAssumed Answered
Issue with Block Adjustment in ArcGIS Pro
Question asked by notnewton on Dec 11, 2018
Latest reply on Jan 22, 2019 by JLenhardt-esristaff
Hi All,
Thanks in advance for helping in any way you can.
I am currently trying to create an orthomosaic but am getting stuck on the Block Adjustment. My input data is RapidEye imagery from Planet Labs. I am using the standard elevation  3d layer that the OrthoMapping tool defaults to upon opening as the elevation source. Before running the adjust tool, I set the reference image as the World Imagery layer then run the adjust tool. No matter what I do, the Ground Control Points, Tie Points, and Check Points computer without any issue. When it gets to running the block adjustment I get:
'ERROR 001934: The adjustment is not applicable to the mosaic dataset.
Failed to execute (CompleteBlockAdjustment).'
I have tried messing with a number of settings but to no avail. No one else seems to have reported this problem so if you have any idea what I should do, I would be very appreciative.
Thanks so much!@
Outcomes
