How do I change the file path for a .lyrx file?
700
12-11-2018 09:08 AM
CherylSannebeck1
I accidentally changed the file path for a .lyrx to an Adobe Acrobat DC file vs the "Opens with: Windows Shell Common." How do I revert the .lyrx back to "Opens with: Windows Shell Common"?
MarisaClaggett
Occasional Contributor II
If you right click on a lyrx file in Windows File Explorer, there should be an option to Open With..., and change the application for which that file type is opened.  Does this work?
Best,
Marisa
CherylSannebeck1
I had tried that option. I actually have a new computer so the problem has been solved.
Thank you,
Cheryl
