AnsweredAssumed Answered
Error in config GeoEvent Input for Azure IoT Hub
Question asked by billxu2007 on Dec 11, 2018
After I add the Azure IoT connector, and config the GeoEvent input as in the attached file, it give me an error:
Status: Error - Create Event Hub Receiver Error:
java.util.concurrent.ExecutionException:
com.microsoft.azure.storage.StorageException: The specifed resource name contains invalid characters
What is the "The specifed resource name" means here?
If this error is about the Event hub connection string or the storage connection string, they are copied from the Azure portal.
I followed the following instruction:
## Device Simulation by Microsoft Azure IoT solution accelerators
https://www.azureiotsolutions.com/Accelerators#description/device-simulation
## [Microsoft Azure Connectors](https://github.com/Esri/azure-for-geoevent)
Outcomes
