Uploading a new service
899
7
12-10-2018 07:11 AM
EvonFranklin
New Contributor III
I get the above error when trying to upload a service from ArcMap and as seen here when trying to enable Feature Access through the server manager, this error occurs. I am not sure what is preventing this from being enabled.
JakeSkinner
Esri Esteemed Contributor
Hi Evon,
Does your data reside in an Enterprise Geodatabse (i.e. SQL Server, Oracle)?  This is required in order to enable Feature Access.
EvonFranklin
New Contributor III
We have an in house SQL server storing all the data populated by the maps.
EvonFranklin
New Contributor III
i will take a look into this now, it is just kind of strange that a few months ago it was working perfectly and we were ready for full time launch as well as buying credits to use more ESRI services, but this has stalled progress quite a bit.
MichaelVolz
What version of SQL Server are you using?
EvonFranklin
New Contributor III
Not sure of that yet, i will ask who set it up for the org and get back.
GeorgeKatsambas
Occasional Contributor III
Check to see if your data is versioned as well, sometimes versioning gets messed up
