AnsweredAssumed Answered
XYTabletoPoint_managment tool error
Question asked by csyoo0717@skku.edu on Dec 8, 2018
I have created a .csv file through following code.
public void CreateCSV(DataTable dataTable, string filePath, string delimiter = ",")
if (!Directory.Exists(System.IO.Path.GetDirectoryName(filePath)))
throw new DirectoryNotFoundException($"Destination folder not found: {filePath}");
var columns = dataTable.Columns.Cast<DataColumn>().ToArray();
var lines = (new[] { string.Join(delimiter, columns.Select(c => c.ColumnName)) })
.Union(dataTable.Rows.Cast<DataRow>().Select(row => string.Join(delimiter, columns.Select(c => row[c]))));
File.WriteAllLines(filePath, lines);
File created successfully and I can manually load and make XY to Point conversion using Geoprocessing tool. It also goes successful but when I try to achieve this through C# code it gives the following error.
GPtool error message
GP tool code is given below
try
string st_in = @"C:\Users\Aizaz\Documents\ArcGIS\Projects\MyProject\new.csv";
string st_out = @"C:\Users\Aizaz\Documents\ArcGIS\Projects\MyProject\Settlement_m";
//var envArray = Geoprocessing.MakeEnvironmentArray(null);
var args = Geoprocessing.MakeValueArray(st_in, "Long", "Lat", "Settlement", st_out, "");
string tool_path = "XYTableToPoint_management";
IGPResult ret = await Geoprocessing.ExecuteToolAsync(tool_path, args/*, envArray*/);
if (ret.IsFailed)
ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show($@"Error {ret.ErrorCode} in GP Tool: {ret.ErrorMessages}");
var rset = Geoprocessing.ExecuteToolAsync(tool_path, args, null, null, GPExecuteToolFlags.Default);
catch
Any idea what this error means? because I cannot find anything about it in ArcGIS Pro examples or online resources etc.....
Outcomes
