You should be able to access it here: ArcGIS Web Application
Do you have any ideas as to why it stopped being able to load. I do not see any problems with the layer in the bridge inspection map (https://ndor.maps.arcgis.com/home/webmap/viewer.html?webmap=b555d6264f4747b4b751cb5fec3a05dc ) or any problems with the layer on the arcgis server. Thanks.
Christopher,
It appears to me that there is some new issue introduced with WAB 2.11 that was released lat night. Do you have an arcade expression in that webmap?
Just for testing try removing that and saving your web map and test the app again. I have seen another thread today about arcade expressions failing in WAB after the update.
Robert,
You seem to be saying something that I wasn't originally aware of and I'm looking for clarification. Are there live updates going to WAB that don't require a user to re-install their version in order to take affect? In this case Christopher had version 2.11 and an update was pushed at night that affected his application correct? Is this an update to the JS API version or to the actual WAB build or perhaps an AGO update?
-Jamal
Has anyone see it where just the Apply button in a Query window stops working? We have a query that has ran for months and now when you hit apply just nothing happens. If we test rebuild the App still nothing. If we rebuild just the map still no. If we rebuild the map and the app it starts working again. The other prebuilt queries are working - it is just this one.
But this map and app have a ton of modifications to it so it is a huge project to rebuild.
Any ideas?
Christopher,
