AnsweredAssumed Answered
Running Model Via Python Script (Hosted Data)
Question asked by andrew.southern@Franklintn.gov_franklin on Dec 6, 2018
Latest reply on Dec 11, 2018 by vonmoosa
Hi.
I used Model Builder to create a model that edits a hosted feature service that runs as expected when run manually.  But when I try to use python to run the model I get a Error 000732 Dataset Not Found Or Supported error.  The code is as follows:
import arcpy
from arcpy import env
arcpy.ImportToolbox(r"C:\Users\andrew.southern\Documents\ArcGIS\Projects\Adopt_A_Storm_Drain\Adopt_A_Storm_Drain.tbx", "Toolbox")
arcpy.Model_Toolbox()
Any ideas as to what I need to do differently?  For data in SDE this script usually works fine but am not experienced with running models against hosted feature services using python.
Thank you.
Outcomes
