Vertical exaggeration is not working
476
12-06-2018 03:04 AM
AxelThomas
New Contributor III
I have been loading a DEM (.img file). It displays alright but when changing vertical exaggeration nothing happens. Is there anything else to do to make vertical exaggeration work?
Thanks, Axel
Mandy_Li
Hi Axel,
Local raster data, elevation image services, and tile packages with LERC tile format can be added as terrain surfaces. Also, you might need to check if your raster data is added to the Terrain tabinstead of the Table of contents.
Mandy
