Legend
674
12-05-2018 05:54 AM
jaykapalczynski
I have a main index.js page
This page defines some Map Services and builds a legend.  This works fine.
I have a couple other .js pages that also display Map Services and I am trying to get them in the same Legend unsuccessfully.
I don't think I have to create a new LEGEND in the LayerList.js page but rather just push the layers from the LayerListPage back to the Index.js page to be included in the already defined LEGEND?
Looking for some thoughts on this....not sure where to go from here...
Notice the unction call to the second .js page  window.LoadLayerList(); in the index.js page
Hope this make sense....
Main Index.js page
//ADD THE LEGEND
window.map.on("layers-add-result", function (evt) {
   // CYCLE through and grab all the layer names to add to the LEGEND PLUS
   // Remove layers not inteneted for the legend.
   var layerInfo = arrayUtils.map(evt.layers, function (layer, index) {
     if (layer.layer.id === "Roads" || layer.layer.id === "Roads1") { return { }; }
   //Hides Layers in the Legend
     else { return { layer: layer.layer, title: layer.layer.name }; } //Else return All others
   if (layerInfo.length > 0) {
     var legendDijit = new Legend({
        map: map,
        layerInfos: layerInfo,
     }, "legend");
   legendDijit.startup();
   legendDijit.refresh();
window.LoadLayerList();     ‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
LayerList.js page
window.LoadLayerList = function(){
  var District2 = new FeatureLayer("https://vafwisdev.dgif.virginia.gov/arcgis/rest/services/Projects/AVL2/MapServer/4", {
     mode: FeatureLayer.MODE_SNAPSHOT,
     opacity: .2,
     visible: true
  legendLayers4.push({ layer: District2, title: 'District Boundary' });
     if (layer.layer.id === "Biologist" || layer.layer.id === "District2") { return { }; } //Hides Layers in the Legend
          map: map,
        }, "legend");
   // ADD MAP LAYERS
jaykapalczynski
I removed all the legend code from the LayerList.js page
Reset the variable of the Feature Layer using  "window."  now its global
        window.WMAFL = new FeatureLayer("https://xx/arcgis/rest/services/Projects/xx/MapServer/4", {
Then just relying on the index.js page to work as normal
       NOTING that I had to define the layer variable in the index.js page that resides in the LayerList.js page  WMAFL is the Feature Layer variable from LayerList.js
       map.addLayers([SafetyBridges, WMAFL ]);
index.js
var SafetyBridges = new FeatureLayer("https://fragis.fra.dot.gov/fragis/rest/services/SafetyBridges/MapServer/0", {
   mode: FeatureLayer.MODE_ONDEMAND
// Push to Layer List
legendLayers6.push({ layer: SafetyBridges, title: 'Safety Bridges' });
//ADD THE LEGEND
     if (layer.layer.id === "PastLocations" || layer.layer.id === "District" ||
  layer.layer.id === "weatherlayer") { return { }; } //Hides Layers in the Legend
     map: map,
     }, "legend");
LayerList.js
// WMA LINE
legendLayers4.push({ layer: WMAFL, title: 'WMA Line' });
RobertScheitlin__GISP
Jay,
   Make the legendDijit a global var using window.legendDijit and update the window.legendDijit.layerInfos properties from the LayerList.js file.
jaykapalczynski
That would work also....but I think they way I posted it might be another way??????  Where I eliminate the duplicating legendDijit code in the LayerList.js file
jaykapalczynski
I was able to get this working....will post shortly.
jaykapalczynski
index.js
//ADD THE LEGEND
     map: map,
     }, "legend");
LayerList.js
// WMA LINE
