Arcgis Runtime Content - Network Analyst "Out of range"
680
12-02-2018 12:17 AM
NoureddineElzaatari
Dears,
im facing a very strange error,
im building a network dataset successfully, on Arcmap adding 2 stops and solving successfully, but when i share the transportation layer as Arcgis Runtime Content routing to the same 2 stops on the deployed IOS app, im getting the following error
Error Domain=com.esri.arcgis.runtime.error Code=4 "Out of range" UserInfo={NSLocalizedFailureReason=, NSLocalizedDescription=Out of range, Additional Message=}
the network solves successfully on the Arcmap but on IOS it is not (only some point but on many others it solves),
what could be the issue ?
is there a way to debug this ?
NoureddineElzaatari
thank you for the hint, it seems that i was using a lower version than 100.4
i had
pod 'ArcGIS-Runtime-SDK-iOS'
where it must be
pod 'ArcGIS-Runtime-SDK-iOS', '100.4'
the moment i changed, the routing works perfectly as expected
i hope that it helps others
FrankKish
Hi - What version of ArcGIS Runtime are you using?
NoureddineElzaatari
100.4.0
NoureddineElzaatari
i had
where it must be
NoureddineElzaatari
i had
where it must be
