I want to select a raster dataset from any path.As i select dataset i want its bands should be visible with checkboxes at runtime.User select two bands and when he press button ok i call my buissness logic function which uses the selected checkboxes.please help .
You can set those parameters up in your tool in the toolbox. Are you having problems with specifying the tool parameters? perhaps if you show how you have your script and toolbox setup you can be pointed in the right direction
