AnsweredAssumed Answered
map.on click produces multiple points with single mouse click
Question asked by mahaley844 on Nov 30, 2018
Latest reply on Nov 30, 2018 by rscheitlin
In JavaScript I have the following function used to place markers on the map and label them. The label offset is changed just so I could see what is going on. When I get it fixed the label offset will not change.
placeMarkers (){
if (dijit.byId("rdoMarkerMethodManual").checked) {
WUAapp.WUAmap.on("click", function (evt) {
markerPoint = null;
markerPoint = new esri.geometry.Point(evt.mapPoint.x, evt.mapPoint.y, new esri.SpatialReference({ wkid: 2903 }));
//var pointCoords = document.getElementById('txtMarkerMethodKeyin').value.split(',');
//markerPoint = new esri.geometry.Point(parseInt(pointCoords[0]), parseInt(pointCoords[1]), new esri.SpatialReference({ wkid: 2903 }));
WUAapp.WUAmap.graphics.add(new esri.Graphic(markerPoint, spotMarkerSymbol));
alert("spotMarker added");
//labelMarker(markerPoint);
if (dijit.byId("rdoLabelNumeric").checked) {
markerLabel = new esri.symbol.TextSymbol(currentMarkerLabel);
markerLabel.setOffset(labelOffset, 0);
labelPointGraphic = new esri.Graphic(markerPoint, markerLabel);
WUAapp.WUAmap.graphics.add(labelPointGraphic);
alert("Numeric Label " + labelCount + " added");
currentMarkerLabel = currentMarkerLabel + incrementInt;
labelCount = labelCount + 1;
labelOffset += 10;
This is called by a button on a form. It works fine the first time you push the button. However if you push the button again, a single mouse click will create 2 points and 2 labels. The third button push creates 3 points and three labels with a single mouse click. etc etc etc. I put the alerts in there to verify the points and labels have been placed.
Is there something that should be cleared?
Outcomes
