AnsweredAssumed Answered
Matching monthly rasters for different variables
Question asked by tonalca6864 on Nov 29, 2018
Latest reply on Nov 29, 2018 by Dan_Patterson
I have a set of raster layers that I need to match monthly and perform a simple operation:
The operation being, for example:
(Aale_Vector_UpW_apr_per + Aale_Vel_UpW_apr_per + Aale_Vvel_UpW_apr_per) / 3
Same for all months.
I've tried the code below with no success (no outputs are produced). It doesn't generate an error either. Obviously, I'm missing something...
# SUM THE MONTHLY PERCENTAGE VALUES FOR EACH PARAMETER AND DIVIDE BY 3 TO KEEP IT AS VALUE BETWEEN 0-100
env.workspace = r"D:\000_TEST_MAGNITUDE_summary\MAX_VAL_calculation\TEST_IN.gdb"
OUTworkspace = r"D:\000_TEST_MAGNITUDE_summary\MAX_VAL_calculation\TEST_OUT.gdb"
# List of rasters
vvelrast = arcpy.ListRasters("*Vvel*")
velrast = arcpy.ListRasters("*_Vel*")
vecrast = arcpy.ListRasters("*Vector*")
# Pair the three monthly parameters
for vvel in vvelrast:
    for vel in velrast:
        for vec in vecrast:
            if vvel[:7] == vel[:7] == vec[:7]:
                outRas = (Raster(vvel) + Raster(vel) + Raster(vec)) / 3
                outRas.save(OUTworkspace + "\\" + vel[:4] + "_Upwelling_mag_" + vel[13:16])
print "DONE"
Outcomes
