I'm attempting to display related non-spatial records from a line feature class and a point feature class hosted in AGOL from a custom Xamarin Forms UWP app built with the ArcGIS Runtime SDK for .NET v100.4. When viewing the related records in AGOL (on both the line and point feature classes) the related data is displayed as expected.
My problem is, my code will display the related records from my line feature class, but I cannot get the related records to display from the point feature class. It is using the same code in both cases, both feature classes and the related tables are added to the map and the relationships are setup identical to each other, just between two different feature classes and tables.
Has anyone else had an issue with this?
See attached images for example of what is working and what is not.
Tim
Can you share the code you use to get the relationship, and also to display the related record. Thanks!
