Parcel Fabric - Export Lots with Parcel ID #
629
11-28-2018 03:25 PM
MichaelKnapp
Hi All -
We're working on scripting the export (via python) of parcel fabric layers so we can push them through our data publishing workflow. We're not having any trouble doing this, but now we'd like to export the "Lots and Units" layer to a Feature Class, but with the Parcel Id # included in the output Feature Class (it's not in this layer by default).
Does anyone have experience python scripting custom exports of parcel fabric layers?
Thanks!
-Mike Knapp
DanielSereno
Aloha Mike,
I am doing something similar to what Frank suggested (spatial join) but for updating the SEWERSERV attribute of the Parcel Publishing feature class, which is going to be similar to what you are looking to do with the Parcel ID#. The following function lives in the same script that builds the Tax Parcel FC that is in the Parcel Publishing FDs, hence, why only one argument to the function (sorry, about the lack of formatting, I tried to manually format it):
# Begin updateSewerserv function to calculate Sewerserv attribute of Parcel Publishing feature class
def updateSewerserv(tax_parcels):
   arcpy.AddMessage("Starting updateSewerserv() function...")
   # source feature
   sourceFeature = r'<UPDATE THIS PATH TO YOUR PARCEL PUBLISHING TAX PARCEL LAYER>'
   # source field
   sourceField = r'Type'
   # target feature
   targetFeature = tax_parcels
   # target field
   targetField = r'<UPDATE THIS TO YOUR ATTRIBUTE>'
   # overlap type
   # overlap_type options ["WITHIN_A_DISTANCE_GEODESIC", "WITHIN_A_DISTANCE",    "WITHIN_A_DISTANCE_3D", "INTERSECT", "INTERSECT_3D", "HAVE_THEIR_CENTER_IN", "CONTAINS",    "WITHIN"]
   overlap_type= r'HAVE_THEIR_CENTER_IN'
   workSpace = targetFeature
   arcpy.env.workspace = workSpace
   oid = "OBJECTID"
   tmpSrcLayer = "in_memory\\tmpSource"
   targetLayer = "in_memory\\tmpTarget"
   if arcpy.Exists(tmpSrcLayer):
      arcpy.Delete_management(tmpSrcLayer)
   if arcpy.Exists(targetLayer):
      arcpy.Delete_management(targetLayer)
   with arcpy.da.SearchCursor(sourceFeature, [oid,sourceField]) as cursorSearch:
      for row in cursorSearch:
         arcpy.MakeFeatureLayer_management(targetFeature, targetLayer)
         arcpy.MakeFeatureLayer_management(sourceFeature, tmpSrcLayer, where_clause = oid + " = " + str(row[0]))
         arcpy.SelectLayerByLocation_management (targetLayer, overlap_type=overlap_type, select_features =          tmpSrcLayer, selection_type = "NEW_SELECTION")
         updateCount = arcpy.GetCount_management(targetLayer)
         with arcpy.da.UpdateCursor(targetLayer,targetField) as cursorUpdate:
            for row2 in cursorUpdate:
               if row[1] == None:
                  pass
               else:
                  row2[0] = row[1]
                  cursorUpdate.updateRow(row2)
               del row2
            arcpy.AddMessage(str(updateCount)+ " features in "+ targetFeature+ "'s field '"+targetField+"' updated to:             "+str(row[1]))
            del cursorUpdate
      del row
   del cursorSearch
   del tmpSrcLayer
   del targetLayer
# End updateSewerserv function
I'd be happy to send you the full script is you'd like.
Mahalo!
Dan Sereno
GIS Manager
County of Maui
MichaelKnapp
Hi Dan... just wanted to say thanks for sharing this!
