Calculated Date field can't be overwritten
202
11-25-2018 08:42 PM
DavidOrridgee
I have a calculated date field based on an earlier question in my form. I am allowed to manually change the date in this field in the form but when submitted it defaults back to the calculated value.
I have been using this form for over a year now and have not noticed this behaviour before.
I also notice the refresh symbol appears after changing the time.
Can calculated fields be manually overwritten?
JamesTedrick
Esri Esteemed Contributor
Hi David,
I'm trying to replicate the behavior you are describing; however, the manual override is being saved instead of the calculated value.  Can you share your XLS file?
