I have 2 dictionaries (A and B). A is a new list of keys which is being checked against B. If a key is in B but not A (is an old value), I'm attempting to get the first value from the associated key in the dictionary (in this case an OBJECTID).
The issues I'm having are with line 32. As far as I can tell, this should iterate through all the keys in B, see if they're in A, and if not, write their value to a text file. As it happens, the text file is just getting the full list of old values (dictionary B) instead of only the ones not in both feature classes/dictionaries. Where are we going wrong?
I've attached the output text file
import arcpy
# Set environmental variables
new = r"W:\Mapping\ArcGIS Online\ArcGIS Online Features.gdb\Collector_patch" #new feature class
old = r"W:\Mapping\ArcGIS Online\Upload.gdb\AGOL_Export" #old feature class
field = 'LinkKey', 'OBJECTID' #feature class fields to compare & return
fout = r"W:\Mapping\ArcGIS Online\FPC Plantations Features to Delete.txt" #output text file
a = {}
b = {}
#The old feature class is loaded into dictionary b
with arcpy.da.SearchCursor(old, (field)) as rows:
for row in rows:
if row[0] not in b:
b[row[0]] = [row[1]]
#The new feature class is loaded into dictionary a
with arcpy.da.SearchCursor(new, (field)) as rows:
for row in rows:
if row[0] not in a:
a[row[0]] = [row[1]]
#Below compares the dictionaries and extracts features with old Linkkeys"
fo = open(fout, "w")
for k, v in b.iteritems():
if k not in a.items()[0]:
print k
print v
fo.write(str(v[0]) + ',')
print "Linkkeys not in new feature class exported"
fo.close()
Just focusing on this line :
Would that be better if it were just:
