my map service published to ArcGIS Server contains a polygon layer and a table related by a real relationship class stored in a file / enterprise geodatabase.
When I add my map service to ArcMap or ArcGIS Online web map and hit identify I get back information about the feature in the polygon layer and its related records in the related table.
ArcGIS Pro doesn't seem to pick up that there is a related table and can't query it? The only way around this is to add both polygon feature class and the table into my ArcGIS Pro map and Add Relate between those two layers. Again.
Are the related tables in a map service supported in ArcGIS Pro? If not, will they ever be supported?
