AnsweredAssumed Answered
UniqueValueRenderer on two ShortInteger fields doesn't deserialize from json correctly
Question asked by kirkKuykendall on Nov 20, 2018
I have a featureclass with two ShortInteger fields that I tried to symbolize with a UniqueValueRenderer that was deserialized from json (Renderer.FromJson).  (v 100.4)
After seeing the wrong symbols on the map, I discovered the values were System.String types.
I replaced the values with Int16s and it displayed correctly.
private void UvrBugWorkaround(UniqueValueRenderer uvr)
    try
        // when a uvr that has multiple short integer fields is deserialized from json,
        // the resulting UVR has string values in it, causing it not to behave as expected
        // (all features get displayed with the "other" symbol)
        // Here is a workaround that replaces the string values with short values.
        foreach(var v in uvr.UniqueValues)
            Debug.Print(v.Label);
            List<short> vals = new List<short>();
            foreach(var v2 in v.Values)
                short i;
                short.TryParse(v2.ToString(), out i);
                vals.Add(i);
                Debug.Print(v2.ToString() + ": " + v2.GetType().ToString());
            v.Values.Clear();
            foreach (var newval in vals)
                v.Values.Add(newval);
        // notice the json remains unchanged ... perhaps the real bug is in the deserializer?
        // (the layer now draws correctly)
        Debug.Print(uvr.ToJson());
    catch (Exception ex)
        Logger.LogException(ex);
Outcomes
