AnsweredAssumed Answered
Text Annotation displaying problem
Question asked by tkoka3 on Nov 21, 2018
Latest reply on Dec 3, 2018 by cmacleod-esristaff
We are develope commands for arcgis pro sdk 2.2 version.We have developed the "Intermediate distance writing " tool.Tool lines are feature class, distance string is the annotation .But annotation (distance string) when I create new one store annotation correctly in  table but  not shown stable in map. When create a new sometimes when I use zoom in/out (change scale), some annotations or all annotations don not display.When I create a new one sometimes all the annotations appear.  Here is the Pictures and Codes below. How can I solve this problem ? Could this problem be a bug?
Pictures:
annotation1
annotation2
Codes:
#region VARIABLES
private BaseBL baseBL = new BaseBL();
private AnnotationBL annotationBL = new AnnotationBL();
private Layer planlamaAlaniLayer;
private FeatureLayer araMesafeLineLayer;
private AnnotationLayer araMesafeLayer;
private Polyline polyline;
private Polyline annotationPolyline;
private MapPoint centerPoint;
private PolylineBuilder polylineBuilder;
private List<Segment> segmentList;
private double distance;
private double mesafe;
private double size;
private int clickCount;
private string planlamaAlaniID;
private string methodBilgi;
private RowCursor cursor;
private AnnotationFeature annoFeature;
#endregion VARIABLES
#region CONSTRUCTOR
public AraMesafeYazMapTool()
IsSketchTool = true;
SketchType = SketchGeometryType.Line;
SketchOutputMode = SketchOutputMode.Map;
UseSnapping = true;
#endregion CONSTRUCTOR
protected override Task<bool> OnSketchCompleteAsync(Geometry geometry)
if (clickCount != 2)
return Task.FromResult(false);
return QueuedTask.Run(() =>
try
if (!KatmanKontrol())
return false;
#region CREATING LINE FEATURES
geometry = GeometryEngine.Instance.Project(geometry, this.araMesafeLayer.GetSpatialReference());
polyline = geometry as Polyline;
if (polyline != null)
this.planlamaAlaniID = Library.GetPlanlamaAlaniID(this.planlamaAlaniLayer, polyline);
if (this.planlamaAlaniID == null)
return false;
this.mesafe = polyline.Length;
this.centerPoint = GeometryEngine.Instance.Centroid(polyline);
this.annotationPolyline = GeometryEngine.Instance.Rotate(polyline, GeometryEngine.Instance.Centroid(polyline), Math.PI / 2) as Polyline;
polylineBuilder = new PolylineBuilder(polyline);
distance = polyline.Length / 2;
if (distance <= 5)
distance = distance - polyline.Length / 8;
else
distance = distance - 2;
polylineBuilder.SplitAtDistance(distance, false);
if (distance <= 5)
distance = distance + polyline.Length / 8;
else
distance = distance + 2;
segmentList = GeometryUtil.GetSegment(polylineBuilder.ToGeometry());
if (segmentList.Count != 3)
return false;
segmentList.RemoveAt(1);
polyline = GeometryEngine.Instance.Union(PolylineBuilder.CreatePolyline(segmentList.FirstOrDefault()), PolylineBuilder.CreatePolyline(segmentList.LastOrDefault())) as Polyline;
if (!baseBL.InsertBaseFeature(MapView.Active, baseBL.CreateBaseFeatureEntity(polyline, null, this.araMesafeLineLayer, this.planlamaAlaniID, ref this.methodBilgi), ref this.methodBilgi, "Ara mesafe yaz - Çizgi ekleme"))
Library.MesajHata(methodBilgi);
return false;
if (mesafe >= 20)
size = 0.1;
else
size = mesafe * 0.1 / 20;
#endregion CREATING LINE FEATURES
 #region CREATING  DİSTANCE ANNOTATİON
var fc = this.araMesafeLayer.GetFeatureClass() as AnnotationFeatureClass;
if (fc == null)
return false;
EditOperation editOperation = new EditOperation();
editOperation.Name = "Mesafe Sembölü";
editOperation.SelectNewFeatures = false;
var cimDefinition = fc.GetDefinition() as AnnotationFeatureClassDefinition;
var labels = cimDefinition.GetLabelClassCollection();
var symbols = cimDefinition.GetSymbolCollection();
if ((labels.Count == 0) || (symbols.Count == 0))
return false;
var label = labels[0];
if (labels.Count > 1)
foreach (var LabelClass in labels)
if (LabelClass.Name == CurrentTemplate.Name)
label = LabelClass;
break;
var symbolName = label.TextSymbol.SymbolName;
int symbolID = -1;
if (!int.TryParse(symbolName, out symbolID))
foreach (var symbol in symbols)
if (symbol.Name == symbolName)
symbolID = symbol.ID;
break;
if (symbolID == -1)
return false;
Dictionary<string, object> values = new Dictionary<string, object>();
values.Add("SymbolID", symbolID);
values.Add("AnnotationClassID", label.ID);
int idxField = cimDefinition.FindField("TextString");
values.Add("TextString", this.mesafe.ToString("0.##"));
values["SHAPE"] = this.annotationPolyline as Geometry;
long newFeatureID = -1;
editOperation.Create(this.araMesafeLayer as Layer, values, oid => newFeatureID = oid);
bool opResult = editOperation.Execute();
if (opResult)
var chainedOp = editOperation.CreateChainedOperation();
chainedOp.Callback(context =>
QueryFilter qf = new QueryFilter();
qf.WhereClause = BaseFeatureEntity.objectIdFieldName + "=" + newFeatureID.ToString();
cursor = fc.Search(qf, false);
cursor.MoveNext();
if (cursor.Current != null)
annoFeature = cursor.Current as AnnotationFeature;
if (annoFeature != null)
var textGraphic = annoFeature.GetGraphic() as CIMTextGraphic;
if (textGraphic != null)
var symbol = textGraphic.Symbol.Symbol;
symbol.SetColor(ColorFactory.Instance.BlackRGB);
var cimTextSymbol = symbol as CIMTextSymbol;
cimTextSymbol.HorizontalAlignment = ArcGIS.Core.CIM.HorizontalAlignment.Center;
cimTextSymbol.VerticalAlignment = ArcGIS.Core.CIM.VerticalAlignment.Center;
cimTextSymbol.SetSize(this.size);
textGraphic.Text = this.mesafe.ToString("0.##");
annoFeature.SetGraphic(textGraphic);
annoFeature.Store();
context.Invalidate(annoFeature);
}, fc);
chainedOp.Execute();
#endregion CREATING  DİSTANCE ANNOTATİON
catch (Exception ex)
Library.MesajHata(ex.ToString());
finally
if (cursor != null)
cursor.Dispose();
annoFeature.Dispose();
clickCount = 0;
return true;
Sample codes we take for reference, Narelle Chedzey suggested codes:
How can I create Text Anntation with given FontSize and Alignment ?
Thanks For Helping
Outcomes
